The E4's only have 10/100 ethernet ports I believe (check) If so you will never exceed 100Mbps. may be OK for you but I would future proof with the GB speed M4's.
Connect like this
Disconnect all cables from your new router (or Mesh first unit) and unplug it. Put the VM Hub into modem mode (see VM website for “how to” details) and wait for the base light to turn magenta/purple (on a Hub3 - but not on a Hub4!). Once it’s in modem mode, the VM hub must then be powered off. Then, set up your own router/Mesh with the WAN port set to be in DHCP mode, it may be pre-set that way anyway. Make sure it’s fully initialised (leave 5 min) and then put in the WAN cable to the VM hub. Now power up the VM hub and you should get a connection. Use the recommended App to connect other Mesh units to the first one. This order only needs to be done the first time you connect the router to the VM hub.
