  • 5
Message 1 of 9
Maximum Virgin Hub 3 max WiFi speeds
What is maximum theoretical speeds on this router via 5ghz and 2.4ghz? I'd like to know so the potential replacement router is also theoretically better (as the range being better is a given).
I saw figures 912Mbps and 216Mbps on a review article but surprisingly cannot find many specs on this device.
  • 11.97K
  • 933
  • 1.53K
Message 2 of 9
Re: Maximum Virgin Hub 3 max WiFi speeds
Any decent gigabit enable Wi-Fi router will give you better Wi-Fi than any VM Hub especially with the Hub in Modem mode.
If the budget allows I would look at something like >> THIS <<
Mike Robinson
  • 5
Message 3 of 9
Thanks for replying again. Yeah saw this monstrosity on Amazon, think I'll pass as it's 'only' two bed apartment. But I'll try find best for my budget.
  • 11.97K
  • 933
  • 1.53K
Message 4 of 9
I use one of >> THESE << and it works flawlessly.
Mike Robinson
  • 5
Message 5 of 9
Forgive an ignorant old man, but would one of the Netgear devices replace the Virgin hub or is it wired to the hub via a network cable?  Apologies for the question but thanks in advance for the answers. 🙂
  • 116
  • 11
  • 29
Message 6 of 9
it would be wired to the virgin hub.
the virgin hub would be put into "modem mode" and pass the WAN IP address straight through to the new device, which would act as your router and wireless access point.
  • 11.97K
  • 933
  • 1.53K
Message 7 of 9
Your Local Area Network (LAN) would look something like this ...
LAN-Modem
Mike Robinson
  • 17.46K
  • 1.84K
  • 3.04K
Message 8 of 9
What would be your budget?
  • 30
  • 5
Message 9 of 9
I'm getting a pretty good experience with the ASUS RT-AX55. I use mine as part of a mesh, but for a smaller 2-bed apartment, I suspect this do well. Wifi-6 for just over £100. If you want so spend a little more, the RT-AX56 or 58 are also good and can be flashed with the Merlin firmware.
Depends on how much you like to tinker!
