on 16-07-2023 10:22
For several days I have been experiencing such significant packet loss / extreme latency that the connection is virtually unusable for most of the day.
There are no locally reported issues, either via the automated telephone line or web page.
All devices have been restarted and cabling checked.
1 | 258750000 | 2 | 40 | 256 qam | 16 |
2 | 138750000 | 4.9 | 38 | 256 qam | 1 |
3 | 146750000 | 4.5 | 38 | 256 qam | 2 |
4 | 154750000 | 4 | 38 | 256 qam | 3 |
5 | 162750000 | 4 | 38 | 256 qam | 4 |
6 | 170750000 | 4 | 38 | 256 qam | 5 |
7 | 178750000 | 3.9 | 38 | 256 qam | 6 |
8 | 186750000 | 3.7 | 38 | 256 qam | 7 |
9 | 194750000 | 3.7 | 40 | 256 qam | 8 |
10 | 202750000 | 3.5 | 38 | 256 qam | 9 |
11 | 210750000 | 3 | 38 | 256 qam | 10 |
12 | 218750000 | 2.2 | 40 | 256 qam | 11 |
13 | 226750000 | 2 | 38 | 256 qam | 12 |
14 | 234750000 | 2 | 38 | 256 qam | 13 |
15 | 242750000 | 2 | 40 | 256 qam | 14 |
16 | 250750000 | 2 | 40 | 256 qam | 15 |
17 | 266750000 | 2 | 40 | 256 qam | 17 |
18 | 274750000 | 1.7 | 40 | 256 qam | 18 |
19 | 282750000 | 1.5 | 40 | 256 qam | 19 |
20 | 290750000 | 1.5 | 40 | 256 qam | 20 |
21 | 298750000 | 1.5 | 40 | 256 qam | 21 |
22 | 306750000 | 1.7 | 40 | 256 qam | 22 |
23 | 314750000 | 1.9 | 40 | 256 qam | 23 |
24 | 322750000 | 2.2 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 1 | 0 |
2 | Locked | 38.9 | 4 | 0 |
3 | Locked | 38.9 | 5 | 0 |
4 | Locked | 38.9 | 6 | 0 |
5 | Locked | 38.9 | 17 | 0 |
6 | Locked | 38.9 | 15 | 0 |
7 | Locked | 38.9 | 4 | 0 |
8 | Locked | 38.9 | 5 | 0 |
9 | Locked | 40.3 | 6 | 0 |
10 | Locked | 38.9 | 5 | 0 |
11 | Locked | 38.9 | 4 | 0 |
12 | Locked | 40.3 | 5 | 0 |
13 | Locked | 38.9 | 5 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 40.3 | 5 | 0 |
16 | Locked | 40.3 | 1 | 0 |
17 | Locked | 40.9 | 5 | 0 |
18 | Locked | 40.3 | 7 | 0 |
19 | Locked | 40.3 | 5 | 0 |
20 | Locked | 40.3 | 3 | 0 |
21 | Locked | 40.3 | 4 | 0 |
22 | Locked | 40.3 | 6 | 0 |
23 | Locked | 40.3 | 1 | 0 |
24 | Locked | 40.3 | 5 | 0 |
1 | 49600000 | 43.8 | 5120 | 64 qam | 1 |
2 | 43100000 | 43.5 | 5120 | 64 qam | 2 |
3 | 30100000 | 42.8 | 5120 | 64 qam | 4 |
4 | 36600000 | 43.3 | 5120 | 32 qam | 3 |
5 | 23600000 | 42.3 | 5120 | 32 qam | 5 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
Getting really fed up of Virgin now!
on 16-07-2023 10:22
16/07/2023 09:11:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2023 08:55:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/07/2023 01:00:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/07/2023 23:30:24 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/07/2023 10:24:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/07/2023 00:12:48 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/07/2023 15:06:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/07/2023 12:12:48 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2023 10:13:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/07/2023 00:58:46 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/07/2023 09:32:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/07/2023 15:31:36 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/07/2023 15:20:19 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/07/2023 15:06:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/07/2023 10:27:22 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/06/2023 00:37:50 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/06/2023 11:40:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/06/2023 11:40:24 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/06/2023 11:39:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 16-07-2023 10:38
First call 0800 561 0061 - use the automated service to see if there is a local service issue.
Use the test below to see if the issue is at the Hub or device.
Once the test begins click on: Run full test to see all the stats for packet loss and jitter.
Typically expect zero to minimal packet loss ( retries ) at the Hub and no (N/A) packet loss at the computer.
on 16-07-2023 10:49
Thanks for your message. I've already checked the automated services.
"RealSpeed is not available on this network" -- in either modem or router mode. There are no dropped Ethernet packets on any network interface, including the Ethernet card plugged directly into the SuperHub. I am confident the problem is at Virgin's end, but have changed all of the cables regardless.
on 16-07-2023 11:26
Make sure all forms of VPN are disabled and try Realspeed again with the Hub in Router mode.
What do the results look like from : https://speed.cloudflare.com/
on 18-07-2023 09:11
Hi @gr83 thanks for reaching out to us on the forums. 👋🏼
I'm sorry to hear about the poor experience you have had with the broadband.
I've checked on our end and can't see any issues affecting the service on the network nor on the line.
May I ask what devices are being affected by this?
Kind regards,
Ilyas.
