  • 6.51K
  • 491
  • 861
Hero
Message 11 of 26
Re: Massive latency spikes and speed drops
You have a few Post RS Errors.
Can you reboot the Hub to see if they clear.
Also two of your upstream channels are at max power of 5.1 (51 in real terms) - keep an eye on them.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 2.25K
  • 165
  • 296
Superfast
Message 12 of 26
1458000005.1512064 qam1
2537000415.1512064 qam4
3274000004.95512064 qam3
4358000264.95512064 qam2
The power levels on your upstream channels are quite high, mine as a comparison:
16029998839512064 qam1
23940002436512064 qam4
34620000736.5512064 qam3
45370002637.5512064 qam2
The power levels are a decimal point out due to a software/firmware bug so yours are 51/49.5 (I've manually corrected mine above).
  • 45
Message 13 of 26
I noticed the BQM issue as well and enabled the setting on my router which should fix it. Do I need to make a new graph or should it update and be ok?
  • 2.25K
  • 165
  • 296
Superfast
Message 14 of 26
It looks like it's just starting to come through so leave it as is.
  • 6.51K
  • 491
  • 861
Hero
Message 15 of 26
The graph will update, you don't need to touch it.
I would advise leaving it running while you are with VM so that you have instant evidence of that side of your Hub.
Mike Robinson
  • 45
Message 16 of 26
I did a reboot of the Hub, here are the results:
1202750000-3.436256 qam9
2138750000-2.435256 qam1
3146750000-2.235256 qam2
4154750000-2.535256 qam3
5162750000-2.735256 qam4
6170750000-2.735256 qam5
7178750000-2.936256 qam6
8186750000-336256 qam7
9194750000-336256 qam8
10210750000-3.736256 qam10
11218750000-3.936256 qam11
12226750000-436256 qam12
13234750000-436256 qam13
14242750000-4.436256 qam14
15250750000-4.236256 qam15
16258750000-3.536256 qam16
17266750000-337256 qam17
18274750000-3.237256 qam18
19282750000-3.437256 qam19
20290750000-3.237256 qam20
21298750000-337256 qam21
22306750000-337256 qam22
23314750000-337256 qam23
24322750000-2.937256 qam24
1Locked36.300
2Locked35.560
3Locked35.750
4Locked35.700
5Locked35.500
6Locked35.700
7Locked36.300
8Locked36.300
9Locked36.650
10Locked36.340
11Locked36.300
12Locked36.360
13Locked36.600
14Locked36.600
15Locked36.600
16Locked36.300
17Locked37.650
18Locked37.300
19Locked37.300
20Locked37.300
21Locked37.350
22Locked37.300
23Locked37.350
24Locked37.300
  • 45
Message 17 of 26
1457999595.1512064 qam1
2536999645.1512064 qam4
3273999864.85512064 qam3
4357999574.95512064 qam2
3ATDMA0000
4ATDMA0000
24/07/2020 10:17:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 10:17:15ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 09:56:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 08:41:47noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 08:41:47ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 08:32:58ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 08:00:52noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 08:00:52ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 07:51:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 07:17:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 07:17:37ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 07:08:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 06:37:3noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 06:37:3ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 06:32:19ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 06:32:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 06:27:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 05:53:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 05:53:22ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 05:44:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6.51K
  • 491
  • 861
Hero
Message 18 of 26
I can see that your BQM is starting to mature but seems to have some spikes.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5ec73a640e087dde50152883a4e828f1cf...
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may not be affecting the area. Be aware that it isn't a manned line.
Mike Robinson
  • 45
Message 19 of 26
I just did a service check on here and called the number and everything seems to be fine, no faults. Is it possible my line may need fixing?
  • 6.51K
  • 491
  • 861
Hero
Message 20 of 26
Post the red block on the BQM it looks awful.
You need to contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Mike Robinson
