Macbook Air connected to wifi but download speed is 0
OAllum
I recently moved into a new flat and have started using Virgin for the first time. Ever since the hub has been turned on, my macbook air has been unable to load webpages consistently. My roommate and I both have iphones with no issues and their laptop works as well.
My macbook connects to the wifi but I am unable to look things up or load any websites. For some reason, for a few minutes at a time, it seems to work perfectly but then it cuts out. Additionally, if I load a page using mobile data for example a Youtube video, and connect back onto the network, it loads perfectly fine.
If anyone have any suggestions/solutions on how to fix this issue they would be greatly appreciated.
Thank you.
5 REPLIES 5
Have a look through these recent threads with similar issues - see if anything in these helps sort it.
____________________________________________________________
APPLE CONNECTION ISSUES
No connectivity on Apple kit may be a MAC filtering issue for Apple devices - see if this has the solution for you….
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-iPhone-Apple-MacBook-amp-HP-Pr...
“LIMIT I.P. TRACKING”
Switching this off solved the speeds issue here….
https://community.virginmedia.com/t5/Networking-and-WiFi/Wifi-slow-on-MacBook-Pro-but-fast-on-all-ot...
__
After a MacOS/iOS update, it may auto turn on Automatic Proxy Discovery for all Wi-Fi networks - so turn it off in network settings as per message 7. In iOs go to Settings>WiFi> tap the blue”I” icon and scroll down and make sure Configure Proxy/‘ is set to off - also that Configure DNS and Configure IP are set to automatic
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-5-macOS-Monterey/td-p/4885920
Cant connect as password is incorrect on iPhone (& Andrex)……. this sorted it…
https://community.virginmedia.com/t5/Networking-and-WiFi/Iphone-can-t-connect-to-Virgin-WIFI-Incorre...
Just moving SIM sorted it here
https://community.virginmedia.com/t5/Networking-and-WiFi/Iphone6s-will-not-connect-to-internet-via-w...
Hi John,
Thanks for the reply. Unfortunately none of the solutions have worked for me. Do you have any further suggestions?
There was this.....
After playing around a bit I found what the actual problem is: the Virgin Media router for some reason doesn't like it when the “Limit IP address tracking” option is on. I simply turned it off and the connection is back at full speed.
Legend
Make sure to disable all forms of VPNs including Apple Private Relay / Private Browsing tools.
And this...
_________
Hub 3 - make sure WPA-PSK is Disabled i.e. WPA2-PSK is the security mode.
Hub 5 - make sure WPA3-SAE is Disabled i.e. WPA2-PSK is the security mode.
Hub 3/4/5 - try with Smart Wi-Fi aka Wireless Channel Optimisation Disabled.
Hub 3/4/5 - try with Auto Channels is Disabled on both 2.4Ghz and 5 Ghz.
