on 18-10-2023 11:34
Ive had this and some TAPO ones work fine until my new HUB 5 was installed….now no joy ..ive tried this
https://community.virginmedia.com/t5/Networking-and-WiFi/Connecting-wifi-plugs/td-p/4114843
..but nothing has changed….any help would be welcomed
Answered! Go to Answer
on 18-10-2023 21:13
on 18-10-2023 11:46
You may need to split your SSID (Network Name) into two, one for the 2.4Ghz band, and one for 5Ghz.
Just a note this won't work well if you have pods, or plan to have them in the future.
on 18-10-2023 11:46
Are these devices unable to see the Wi-Fi from the Hub 5 ? Or is there some other type of problem ?
on 18-10-2023 13:12
"until my new HUB 5 was installed" this is because the smart plugs are remembering the SSID of your old hub. There are two ways to fix this:
1) reset the plugs to their ‘shipped’ state and install them as if new.
2) change the SSID on your new hub to be what the SSID was on your old hub.
on 18-10-2023 20:42
How do i do this?
Thanks in advance
on 18-10-2023 21:13
