M500 very slow speed and cant get hold of technician
HI,
I switched from M350 to M500 last month and ever since my speed has dropped to an average of 20-28MPS although I have had a couple of days as high as 180. 2 engineers have come out. The first checked everything inside my property and confirmed everything was fine. the second checked my connection between the box at the end of my rd and my property and again said everything was fine and said that it is obviously a network issue and that someone would be in touch. that was 3 weeks ago. I have tried several times to call and have been stuck on queues varying from 1 hour to 1.5 hours for the tech team. There is no way to contact the tech team other than through the usual  numbers. What is so frustrating is that there is no email address I can write to. Does anybody have a contact email address please?
  • 12.06K
  • 939
  • 1.54K
Re: M500 very slow speed and cant get hold of technician
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 24.94K
  • 1.44K
  • 3.17K
Are those wired or wireless speeds?
