glennr777
  • 8
M350 speed seems slow
Hello,
I've recently moved property and taken my existing Virgin Media equipment with me.  Having now set up in the new property the internet felt a little slower than usual so I've run a test on SpeedTest.net to discover I'm averaging around 90mps.
I'm running my Hub 3.0 in Modem Mode, hooked up to a DD-WRT firmware router (with pretty much stock settings) all through CAT6 and higher and my Win 10 PC reports it's connected at gigabit speed.
All my SNR DB's under Downstream show at 38/40 but I did notice I'm getting errors on channel 20?
Any ideas (thanks in advance 🙂 )
1402750000-240256 qam30
2202750000040256 qam9
3210750000-0.538256 qam10
4218750000-0.740256 qam11
5226750000-2.238256 qam12
6234750000-2.238256 qam13
7242750000-240256 qam14
8250750000-238256 qam15
9258750000-238256 qam16
10266750000-238256 qam17
11274750000-2.238256 qam18
12282750000-2.238256 qam19
13290750000-239256 qam20
14298750000-1.738256 qam21
15306750000-1.440256 qam22
16314750000-1.240256 qam23
17322750000-0.740256 qam24
18330750000-0.440256 qam25
19370750000-2.240256 qam26
20378750000-240256 qam27
21386750000-240256 qam28
22394750000-240256 qam29
23410750000-2.240256 qam31
24418750000-2.240256 qam32
1Locked40.3490
2Locked40.31900
3Locked38.92230
4Locked40.32411
5Locked38.62230
6Locked38.92330
7Locked40.31690
8Locked38.91810
9Locked38.91740
10Locked38.91690
11Locked38.93020
12Locked38.92880
13Locked40.33820
14Locked38.93900
15Locked40.32920
16Locked40.33970
17Locked40.32840
18Locked40.3820
19Locked40.9600
20Locked40.3147305
21Locked40.9820
22Locked40.3620
23Locked40.3920
24Locked40.3510
gary_dexter
  • 30.6K
  • 1.9K
  • 4.07K
Re: M350 speed seems slow
Check the coax connection is seated properly and tightly.
90Mbps could also indicate an Ethernet cable fault.
glennr777
  • 8
Thanks for the quick advice - once my 12 year old gives me permission to take the internet down for 15 mins I'll give this route a check.
lotharmat
  • 937
  • 70
  • 141
Well-informed
They're like little terrorists!!!
glennr777
  • 8
Change of cable (new CAT8 from Hub to Router) looks to have bumped speed up to around 150mbp-ish so it's an improvement. Will keep digging though - ta
Sofia_B
  • 422
  • 18
  • 48
Hi @glennr777.
Thanks for your post 🙂
I'm sorry to hear you're experiencing slow speeds, I appreciate this is frustrating and we apologise for any inconvenience caused.
I've managed to locate your account and everything seems to be performing as it should on our end, please keep us updated on how things perform with the new ethernet cable.
Sofia
