Cloudy73
  • 6
Message 1 of 10
M350 Half Speed issues.
Morning Folks,
Looking for advice here please. I've had a great time with VM and on a M350 package. I usually get a rock solid 350MB connection, usually showing more and above when doing speed checks etc, but have now noticed I seem to be stuck in a 140-170Mb band. Could someone please have a look at these results for me please.
To note: I have performed a full pinhole reset on the SuperHub3, all tests have been carried out via direct cat5e cable to router, coax connection removed, cleaned and screwed back in.
Cable Modem Status
Item
Status
Comments
331000000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
5.5
38
256 qam
25
2
203000000
5.5
38
256 qam
9
3
211000000
5.5
38
256 qam
10
4
219000000
5.5
38
256 qam
11
5
227000000
5.5
38
256 qam
12
6
235000000
5.5
38
256 qam
13
7
243000000
5.5
38
256 qam
14
8
251000000
5.4
40
256 qam
15
9
259000000
5.3
40
256 qam
16
10
267000000
5.1
40
256 qam
17
11
275000000
5
38
256 qam
18
12
283000000
5.1
40
256 qam
19
13
291000000
5.1
38
256 qam
20
14
299000000
5.5
38
256 qam
21
15
307000000
5.5
40
256 qam
22
16
315000000
5.5
38
256 qam
23
17
323000000
5.5
38
256 qam
24
18
339000000
5.5
38
256 qam
26
19
347000000
5.4
38
256 qam
27
20
355000000
5.4
38
256 qam
28
21
363000000
5.4
38
256 qam
29
22
371000000
5.4
38
256 qam
30
23
379000000
5.5
38
256 qam
31
24
387000000
5.5
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
14
0
2
Locked
38.9
7
0
3
Locked
38.6
6
0
4
Locked
38.9
11
0
5
Locked
38.9
21
0
6
Locked
38.9
11
0
7
Locked
38.9
18
0
8
Locked
40.3
6
0
9
Locked
40.3
16
0
10
Locked
40.3
11
0
11
Locked
38.9
15
0
12
Locked
40.3
6
0
13
Locked
38.9
8
0
14
Locked
38.6
16
0
15
Locked
40.3
7
0
16
Locked
38.9
9
0
17
Locked
38.9
15
0
18
Locked
38.9
11
0
19
Locked
38.9
8
0
20
Locked
38.9
7
0
21
Locked
38.9
15
0
22
Locked
38.9
6
0
23
Locked
38.6
8
0
24
Locked
38.9
6
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
40.8
5120
64 qam
2
2
46200000
40.8
5120
64 qam
3
3
39400000
41
5120
64 qam
4
4
60300000
40.8
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
22/04/2021 22:56:27
critical
22/04/2021 12:51:13
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 12:49:37
critical
22/04/2021 08:38:28
notice
22/04/2021 08:37:46
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38
critical
21/04/2021 22:27:7
notice
21/04/2021 22:27:0
Warning!
21/04/2021 21:58:1
notice
21/04/2021 21:39:56
critical
21/04/2021 16:05:52
notice
01/01/1970 00:01:45
critical
21/04/2021 15:58:0
notice
21/04/2021 15:51:32
critical
21/04/2021 15:12:37
notice
21/04/2021 15:12:31
Warning!
21/04/2021 12:06:51
notice
21/04/2021 10:19:1
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 10:19:1
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 10:18:52
Warning!
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 2 of 10
Re: M350 Half Speed issues.
Have you checked to see if there are any network outages in the area?
The most useful and up to date info comes from the 0800 561 0061 number. Try that to see if there are any faults that the web service hasn't picked up!
Cloudy73
  • 6
Message 3 of 10
No known faults / outages at present
lotharmat
  • 838
  • 56
  • 119
Well-informed
Message 4 of 10
The figures - to my pretty untrained eye - don't look too bad - The t3 time outs could be indicative of a problem!
VM Staff should be along shortly to have a look!
Have you set a Broadband Quality Monitor? - This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
If you have, can you share your 'live graph'
Cloudy73
  • 6
Message 5 of 10
Hi Iotharmat,
I've foolishly saved the monitor details as a image only and deleted the live running monitor  -think a mod will need to approve the original post images?
Thank you for helping.
Ohh - Its up now 😉
Cloudy73
  • 6
Message 6 of 10
Still getting 120-150Mb.
I'll leave this for a MOD to glance over.
Cheers
Corey_C
  • 3.39K
  • 185
  • 269
Message 7 of 10
Thanks for your post and updates, Cloudy73,
Sorry to hear that you have been having connection issues. How has things been since your post?
I have run a remote diagnostic and have not been able to identify any issues with your connection. Is this on wired as well as wireless connections and are you connecting through a VPN?
We can also provide online broadband help here: https://www.virginmedia.com/help/services-support/broadband
Let us know if you need any further help.
Cheers,
Corey C
Cloudy73
  • 6
Message 8 of 10
Hi Corey,
All testing is done via Cat5e cable - I've left this a few days but router stats now showing alot more errors:
1Locked38.94456781151
2Locked38.93079933871
3Locked38.626491781645
4Locked40.322339201233
5Locked40.320708261531
6Locked38.919265641424
7Locked38.917099861458
8Locked40.314271501374
9Locked40.312079091558
10Locked40.310606842053
11Locked40.39695241476
12Locked40.38290741809
13Locked38.98580222335
14Locked38.97962481765
15Locked40.96571281524
16Locked38.95788031510
17Locked38.94714801974
18Locked40.34592941536
19Locked38.95623591691
20Locked38.99356831434
21Locked38.915356951534
22Locked38.625790481221
23Locked38.939175411583
24Locked40.35706816
1773
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
Network LogTime Priority Description
29/04/2021 03:10:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 03:10:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 02:15:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 02:15:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 02:06:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 02:06:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 08:29:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 14:04:0noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 22:56:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 12:51:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 12:49:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 08:38:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 08:37:46Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 22:27:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 22:27:0Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 21:58:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 21:39:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 16:05:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
My speed seems to almost back to full 350mb plus which is strange with those errors??
Many thanks,
Cloudy73
  • 6
Message 9 of 10
reboot.....
1Locked38.990
2Locked38.660
3Locked40.370
4Locked40.3250
5Locked40.3150
6Locked38.9190
7Locked38.9210
8Locked40.3170
9Locked38.980
10Locked38.990
11Locked40.370
12Locked38.9270
13Locked38.9110
14Locked38.9130
15Locked40.3150
16Locked40.370
17Locked40.320
18Locked40.370
19Locked40.350
20Locked38.960
21Locked38.930
22Locked40.370
23Locked38.9140
24Locked38.970
16030000040.8512064 qam1
24620000040.8512064 qam3
33940000040.8512064 qam4
45370000040.8512064 qam2
3ATDMA0000
4ATDMA0010
30/04/2021 18:36:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 08:30:29noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:19:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:18:46criticalTFTP Request Retries exceeded, CM unable to register
30/04/2021 01:18:46criticalTFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:18:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:09:18criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:07:10Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:07:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 01:07:4criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 23:56:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Speeds seems ok again.
Many thanks.
Lee_R
  • 2.52K
  • 135
  • 235
Message 10 of 10
Hi @Cloudy73 thanks for getting back to us.
I've had another look from here and cannot find anything locally nor specific to your address that explains the issue you have raised.  Can you please confirm if you've tried a pinhole reset?  You can check how from here . Although I would always recommend up to 45 seconds instead of the 10 seconds the website advises.
Lee_R
