  • 6
Message 1 of 9
Low speed, loosing WiFi connection and Loosing sound on Zoom conference calls
Hello, We're on M100 using HUB3 yet experiencing Response Time: 26ms
Download Speed: 24.3Mbps and Upload Speed: 5.3Mbps which is well below the guaranteed minimum speed.
Virgin's WiFi signal scanner says "Great" signal strength yet its diagnostics tell me to move devices closer to the hub as they have poor signal strength!
Video is good on Zoom calls but I'm told by participants that my audio keeps dropping out.
I have previously reported the disconnection problems but was told I had a "WiFi blackspot" and had to have and pay for WiFi boosters. I disagreed but was told have to try them. I installed the WiFi booster and got no signal at all ! I telephoned but was told I had to speak to technicians again. After being on hold for over an hour, I gave up.
I've followed the instructions on a previous posting to obtain hub information.  However, when I try to post the up and down stream channel and network log info, I get an error message saying "message cannot exceed 20,000 characters" ! I guess I will have to post them separately.
I tried to do this but then got another error message "Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied." !!
Tried again and got another message "The message tags contain and, which is not permitted in this community. Please remove this content before sending your post."
I'd be very grateful if someone with technical knowledge could look at the details and let me know if they can see a problem. Alternatively, advise on where I should look. Thanks.
Cable Modem Status
Item
Status
Comments
427000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
427000000
0
40
256 qam
37
2
267000000
-1.5
38
256 qam
17
3
275000000
-1.2
38
256 qam
18
4
283000000
-0.7
38
256 qam
19
5
291000000
-1.2
38
256 qam
20
6
299000000
-0.2
38
256 qam
21
7
307000000
0.2
38
256 qam
22
8
315000000
-1
38
256 qam
23
9
323000000
-0.2
38
256 qam
24
10
331000000
1
38
256 qam
25
11
339000000
1
38
256 qam
26
12
347000000
0.5
38
256 qam
27
13
355000000
0.5
38
256 qam
28
14
363000000
0.7
38
256 qam
29
15
371000000
0.4
38
256 qam
30
16
379000000
0.5
38
256 qam
31
17
387000000
-0.2
38
256 qam
32
18
395000000
0.5
38
256 qam
33
19
403000000
0.2
38
256 qam
34
20
411000000
0
38
256 qam
35
21
419000000
-0.4
38
256 qam
36
22
435000000
0
38
256 qam
38
23
443000000
-0.2
38
256 qam
39
24
451000000
0.2
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
227
0
2
Locked
38.6
793
0
3
Locked
38.9
239
0
4
Locked
38.6
1289
0
5
Locked
38.6
2599
0
6
Locked
38.6
860
0
7
Locked
38.9
208
0
8
Locked
38.9
310
0
9
Locked
38.9
123
0
10
Locked
38.9
132
0
11
Locked
38.9
155
0
12
Locked
38.9
136
0
13
Locked
38.9
106
0
14
Locked
38.9
152
0
15
Locked
38.6
171
0
16
Locked
38.9
239
631
17
Locked
38.9
323
74
18
Locked
38.9
252
0
19
Locked
38.9
298
0
20
Locked
38.9
368
0
21
Locked
38.9
302
0
22
Locked
38.9
360
0
23
Locked
38.9
378
0
24
Locked
38.6
492
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
4.9
5120
64 qam
3
2
32600000
4.9
5120
64 qam
5
3
39400000
4.9
5120
64 qam
4
4
53700000
4.9
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 12.3K
  • 952
  • 1.58K
Message 2 of 9
Re: Low speed, loosing WiFi connection and Loosing sound on Zoom conference calls
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
  • 17.59K
  • 1.85K
  • 3.06K
Message 3 of 9
What are your connections like on devices connected on ethernet cables? Do the speedtests at speedtest.net on a webrowser on an ethernet connected computer/laptop and see whet thet gets.
When posting and you get the exceeded characters/HTML message - usually if you just click submit again it strips it out and posts ok.
  • 6
Message 4 of 9
Thanks. We've been using only WiFi for years without any problems. Since the problems started, we've had two replacement hubs in the past 6 months. I will try connecting via ethernet and run the speed tests to see what I get.
  • 6
Message 5 of 9
Thanks. Did as you suggested. Wifi signal strength still going up and down. I'll run a speed test on Ethernet cable and see what that shows.
  • 6
Message 6 of 9
Ran the test as you suggested using Ethernet cable right next to the hub. Results below.....
INDIVIDUAL RESULTSExport Results
DATE /TIME  PING
ms DOWNLOAD
Mbps UPLOAD
MbpsDISTANCE
miLOCATION /SERVERPROVIDER
10/19/2020
5:57 PM
8
105.64
9.92
~ 50
Manchester
TNP Ltd.
Virgin Media
  • 17.59K
  • 1.85K
  • 3.06K
Message 7 of 9
OK speeds are fine on ethernet cable so you just have a wifi issue. Things change and 3 Hubs have the same problem so it says that the Hub wifi is being overwhelmed by other signals possible outwith your control(neighbours?).
I would suggest connecting as many devices as possible (especially when on Zoom) by ethernet cable and/or do as I and many other on here do and that is to ditch the VM Hub wifi and get your own better quality wireless equipment. I have never used Hub wifi and have never had any wifi issues.
  • 6
Message 8 of 9
Thanks. Re neighbours WiFi. BT recently installed pole mounted fibre broadband units opposite our house. I've used WiFi Analyzer phone app which has shown one BT WiFi with a signal strength at over 100 dBm. What Wifi unit do you use ?
  • 6
Message 9 of 9
Sorry just read the info at the bottom of your posting. You're using Apple Airport Extreme router.
