  • 14
Message 1 of 8
Low download speed, high ping and high packet loss
Our internet has been rubbish for over 6 months now and no one at Virgin has helped. We get very large spikes of latency and packet loss. Our internet also completely cuts out around every hour or two. Also we are paying for 220mbps but most of the time we only get 1.75mbps. I would appreciate it if anyone can help. Thanks.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ebd47ba061fbb45b27f9a67a81f242b2f7...
  • 11.97K
  • 933
  • 1.53K
Message 2 of 8
Re: Low download speed, high ping and high packet loss
Your BQM is awful.
Can you please
Mike Robinson
  • 14
Message 3 of 8
1394000004.2512064 qam2
2462000404.275512064 qam1
3258000104.175512064 qam4
4326001174.175512064 qam3
3ATDMA0000
4ATDMA0000
  • 14
Message 4 of 8
1475000000736256 qam9
24110000007.536256 qam1
34190000007.336256 qam2
44270000007.436256 qam3
54350000007.336256 qam4
64430000007.436256 qam5
7451000000736256 qam6
84590000006.836256 qam7
94670000006.836256 qam8
10483000000736256 qam10
114910000006.636256 qam11
124990000006.536256 qam12
135070000006.436256 qam13
145150000006.536256 qam14
155230000006.836256 qam15
165310000006.837256 qam16
175390000006.536256 qam17
185470000006.137256 qam18
19555000000636256 qam19
205630000006.136256 qam20
215710000005.536256 qam21
22579000000537256 qam22
23587000000536256 qam23
245950000005.536256 qam24
1Locked36.6924071097
2Locked36.31836571073
3Locked36.6167370910
4Locked36.61404981079
5Locked36.61201441020
6Locked36.3106894953
7Locked36.31105721087
8Locked36.31307461020
9Locked36.6121854875
10Locked36.380891881
11Locked36.684193778
12Locked36.680366973
13Locked36.373959978
14Locked36.668090770
15Locked36.658279859
16Locked37.346861730
17Locked36.845554957
18Locked37.341825736
19Locked36.637493847
20Locked36.633882977
21Locked36.829185730
22Locked37.322758820
23Locked36.619766953
24Locked36.69885762
  • 14
Message 5 of 8
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID194882
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID194881
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 14
Message 6 of 8
Thanks for the help. Network Log
07/11/2020 13:13:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:13:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:13:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:13:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:13:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:13:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:02:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:02:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:02:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:01:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:01:31criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:01:31criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:01:21criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 13:01:21criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 20:07:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 20:07:14criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 20:07:14criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 20:00:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 20:00:25criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.97K
  • 933
  • 1.53K
Message 7 of 8
You can either call in as internet is slow and dropping out (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 14
Message 8 of 8
Thanks a lot for the help.
