  • 15
Message 11 of 26
Re: Low Speeds Wired and Wifi m350
Wired Laptop Windows 10:
1 419000000 -1.9 37 256 qam 32
2 203000000 3.2 38 256 qam 9
3 211000000 3 38 256 qam 10
4 219000000 2.9 38 256 qam 11
5 227000000 2.5 38 256 qam 12
6 235000000 2.2 37 256 qam 13
7 243000000 2 37 256 qam 14
8 251000000 1.7 37 256 qam 15
9 259000000 1.4 37 256 qam 16
10 267000000 1.2 37 256 qam 17
11 275000000 1 37 256 qam 18
12 283000000 0.9 37 256 qam 19
13 291000000 0.5 37 256 qam 20
14 299000000 0.5 37 256 qam 21
15 307000000 0.7 38 256 qam 22
16 315000000 0.7 37 256 qam 23
17 323000000 0.5 37 256 qam 24
18 363000000 0 37 256 qam 25
19 371000000 -0.5 37 256 qam 26
20 379000000 -0.7 37 256 qam 27
21 387000000 -1 37 256 qam 28
22 395000000 -1.5 37 256 qam 29
23 403000000 -2.5 37 256 qam 30
24 411000000 -2.7 37 256 qam 31
1 Locked 37.6 3 0
2 Locked 38.9 7 0
3 Locked 38.6 3 0
4 Locked 38.9 19 0
5 Locked 38.6 23 0
6 Locked 37.6 23 0
7 Locked 37.6 7 0
8 Locked 37.6 10 0
9 Locked 37.6 7 0
10 Locked 37.6 11 0
11 Locked 37.6 13 0
12 Locked 37.6 21 0
13 Locked 37.6 12 0
14 Locked 37.6 20 0
15 Locked 38.6 20 0
16 Locked 37.6 20 0
17 Locked 37.6 8 0
18 Locked 37.6 1 0
19 Locked 37.6 10 0
20 Locked 37.6 4 0
21 Locked 37.6 6 0
22 Locked 37.6 12 0
23 Locked 37.3 22 0
24 Locked 37.3 5 0
1 25800056 3.35 5120 64 qam 6
2 32600017 3.45 5120 64 qam 5
3 39399979 3.45 5120 64 qam 4
4 46199981 3.5 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
08/07/2020 10:39:58 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 10:35:20 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 18:03:28 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 17:15:7 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 05:22:8 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 13:50:5 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 13:57:48 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 03:23:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 18:14:46 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 11:37:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:15:40 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 08:54:49 notice SW download Successful - Via Config file
02/07/2020 08:53:2 notice SW Download INIT - Via Config file
23/06/2020 16:23:53 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/06/2020 16:05:37 notice SW download Successful - Via Config file
23/06/2020 16:00:0 notice SW Download INIT - Via Config file
28/05/2020 02:07:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 15:18:51 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 15:18:47 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 15:18:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 15
Message 12 of 26
i just dont understand i just did a speedtest wired on laptop 350mbps is hit, but wired anything else is only 40mb it really makes no sense
  • 24.4K
  • 1.4K
  • 3.1K
Message 13 of 26
If the "anything else" is a console then 40Mb is to be expected since you'll never achieve full speeds on a console.
  • 15
Message 14 of 26
When we first had virgin media we had 2 wired connections and they were both hitting 200mb no trouble then a week later it just all went downhill
  • 3.47K
  • 270
  • 467
Superfast
Message 15 of 26
It may be worth trying the suggestion in this link:
https://thetechieguy.com/boost-your-ps4-internet-speed-lag
  1. Log into your PS4
  2. Head up to Settings
  3. Find the Network settings
  4. Choose WiFi (ideally select LAN if you have a wired connection)
  5. Select CUSTOM
  6. Connect to your home WiFi
  7. Select automatic settings until you see the DNS screen.
  8. Choose Manual and enter 1.1.1.1 as your Primary DNS and 1.0.0.1 as your Secondary DNS which is CloudFlare’s DNS. If this doesn’t increase your speed, you can also try to enter Google’s DNS which is: 8.8.8.8 for the Primary DNS and 8.8.4.4 for the Secondary DNS.
  • 12
Message 16 of 26
Try changing the port the console is connected to on the router, I'm encountering a problem where my wired connection is slow until I switch port.
  • 24.4K
  • 1.4K
  • 3.1K
Message 17 of 26
Changing DNS won't resolve speed limitations
  • 24.4K
  • 1.4K
  • 3.1K
Message 18 of 26
What were these 2 devices?
  • 15
Message 19 of 26
port forwarding or just changing the slot? if changing the slot i had a problem before having the new hub and still having a problem no matter what slot i use
  • 15
Message 20 of 26
ive tried this no difference
