on 03-11-2023 09:07
HI everyone,
I've had super-stable service for 3yrs now, but in the last 10 days service has become super unstable with download speeds fluctuating from a normal of 800-900mbps to lows of 100-200mbps, multiple times a day. Upload speeds are fine (110-120mbps) and latency is great (10-14ms)
I've had two engineer visits, where they moved the tap (which increased power levels from c.0-1db to c.4-6db (I have a 6gb attenuator fitted)), and they checked for ingress by re-terminating the cable and replaced the isolator.
Looking at the stats, it looks like i have an issue on 3 channels at 2100-2260mhz with 500 million+ Post-RS errors?
3.0 Downstream channels
1 | 330000000 | 6.5 | 36 | QAM 256 | 25 |
2 | 210000000 | 5.9 | 27 | QAM 256 | 10 |
3 | 218000000 | 5.8 | 27 | QAM 256 | 11 |
4 | 226000000 | 5.6 | 28 | QAM 256 | 12 |
5 | 234000000 | 5.4 | 28 | QAM 256 | 13 |
6 | 242000000 | 5.2 | 29 | QAM 256 | 14 |
7 | 250000000 | 4.7 | 29 | QAM 256 | 15 |
8 | 258000000 | 4.5 | 30 | QAM 256 | 16 |
9 | 266000000 | 4.8 | 31 | QAM 256 | 17 |
10 | 274000000 | 5.2 | 32 | QAM 256 | 18 |
11 | 282000000 | 5.2 | 33 | QAM 256 | 19 |
12 | 290000000 | 5.2 | 34 | QAM 256 | 20 |
13 | 298000000 | 5.8 | 34 | QAM 256 | 21 |
14 | 306000000 | 6.5 | 35 | QAM 256 | 22 |
15 | 314000000 | 6.5 | 35 | QAM 256 | 23 |
16 | 322000000 | 6.5 | 35 | QAM 256 | 24 |
17 | 338000000 | 6.7 | 36 | QAM 256 | 26 |
18 | 346000000 | 6.7 | 36 | QAM 256 | 27 |
19 | 354000000 | 6.6 | 36 | QAM 256 | 28 |
20 | 362000000 | 6.6 | 36 | QAM 256 | 29 |
21 | 370000000 | 6.5 | 36 | QAM 256 | 30 |
22 | 378000000 | 6.4 | 36 | QAM 256 | 31 |
23 | 386000000 | 6.3 | 36 | QAM 256 | 32 |
24 | 394000000 | 6.1 | 37 | QAM 256 | 33 |
25 | 402000000 | 5.7 | 36 | QAM 256 | 34 |
26 | 410000000 | 5.5 | 36 | QAM 256 | 35 |
27 | 418000000 | 5.5 | 36 | QAM 256 | 36 |
28 | 522000000 | 5.9 | 37 | QAM 256 | 37 |
29 | 530000000 | 6 | 37 | QAM 256 | 38 |
30 | 538000000 | 6 | 37 | QAM 256 | 39 |
31 | 546000000 | 6 | 37 | QAM 256 | 40 |
1 | Locked | 36 | 3648918 | 0 |
2 | Locked | 27 | 2893225144 | 573150937 |
3 | Locked | 27 | 3111544092 | 59228791 |
4 | Locked | 28 | 2139420914 | 1477331 |
5 | Locked | 28 | 462717082 | 16647 |
6 | Locked | 29 | 2725584720 | 42 |
7 | Locked | 29 | 1672364275 | 3 |
8 | Locked | 30 | 803050519 | 1 |
9 | Locked | 31 | 161034016 | 0 |
10 | Locked | 32 | 31494651 | 0 |
11 | Locked | 33 | 15852872 | 0 |
12 | Locked | 34 | 8961512 | 0 |
13 | Locked | 34 | 6323775 | 0 |
14 | Locked | 35 | 5191454 | 0 |
15 | Locked | 35 | 4642475 | 0 |
16 | Locked | 35 | 4125783 | 0 |
17 | Locked | 36 | 3228336 | 0 |
18 | Locked | 36 | 2830903 | 0 |
19 | Locked | 36 | 2900566 | 0 |
20 | Locked | 36 | 3251102 | 0 |
21 | Locked | 36 | 3616827 | 0 |
22 | Locked | 36 | 4025770 | 0 |
23 | Locked | 36 | 4596840 | 0 |
24 | Locked | 37 | 5662513 | 0 |
25 | Locked | 36 | 8394624 | 0 |
26 | Locked | 36 | 9973161 | 0 |
27 | Locked | 36 | 9048652 | 0 |
28 | Locked | 37 | 8715626 | 0 |
29 | Locked | 37 | 9023826 | 0 |
30 | Locked | 37 | 8797834 | 0 |
31 | Locked | 37 | 9649771 | 0 |
3.1 Downstream channels
159 | 92 | 4K | 1800 | QAM 4096 | 1128 |
159 | Locked | 38 | 6.5 | 2982152492 | 0 |
3.0 Upstream channels
0 | 49600000 | 42.8 | 5120 | QAM 64 | 9 |
1 | 43100000 | 42.5 | 5120 | QAM 64 | 10 |
2 | 36600000 | 42.5 | 5120 | QAM 64 | 11 |
3 | 30100000 | 42.3 | 5120 | QAM 64 | 12 |
4 | 23600000 | 42 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
14 | 10 | 36.7 | 2K | QAM 128 |
14 | OFDMA | 200 | 74000000 | 15 | 1 |
on 09-12-2023 16:51
Thanks for following up!
Super stable and consistent since the cabinet was repaired on Wednesday. Latency to the modem is also c.9ms and near zero jitter. Perfect again.
on 11-12-2023 17:03
Hello soylent.
Thank you so much for your update.
Really is good to see the service has stabilised for you.
If you need anything else, you know where we are.
Gareth_L
