That BQM doesn't show utilisation problems. Based on the regular cycling of the packet loss, it is most likely cause is a failing active component (eg signal amplifier where the fault occurs when well loaded) in one of the street cabinets, and nothing to do with your hub, or your individual line.
The fault needs passing to a senior technician or to the networks team.
