Longer Fibre Optic Cable For Hub 5X
DynamiteDez
I don't suppose anyone knows if it's possible to request or purchase a longer fibre optic cable for the hub 5x to reposition it? We have somewhat of an awkward living room with the nearest sockets etc
The engineer was kind enough to supply us with their longest cable which I think is around 5m but doesn't quite stretch to where our previous router was located. We previously had a 10m modem cable running around the living room.
Thanks!
3 REPLIES 3
Roger_Gooner
Call VM to get a longer cable installed, it will cost £25.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
carl_pearce
Community elder
Check the connector, however something like this should work:
https://www.amazon.co.uk/Elfcam-Singlemode-Delivery-Extending-Compatible/dp/B08MBD4RMP
Reece_MH
Hi DynamiteDez 👋
Thanks for posting, and a warm welcome to the Community Forums.
I'm sorry to hear you have had your Hub installed in a location that's not suitable for you. I'm going to send you a private message, so we can look into this for you and assist.
Please look out for it in the top-right, white envelope or by tapping "Messages" after tapping your profile picture.
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
