  • 8
Message 1 of 23
Log on to work network suddenly not possible
New to this forum. Would appreciate any help. Have worked at home 2-3 days a week since Covid19 started. Have a work laptop which on logging on uses BigIP edge client (Egress switch) to link me to the work network and it usually does it automatically at log in.  All has been fine until 1 week ago when it stopped doing that and just sticks at connecting to downloading/ waiting to connect to server and says it is in offline mode.
I did the usual restart the computer, restart the WiFi and it made no difference. But we have WiFi on our phones and other computers working ok. It even shows on the work laptop that WiFi is connected. I can get into the internet but not the network on the laptop.
Ive had the IT guys reset the laptop at work but the issue persists. However I visited my mum today (part of our bubble) and the laptop worked fine there on her broadband ( not Virginmedia)and connected to my work network. So must be a broadband/ WiFi issue.
Trying to get support and an engineer out from Virgin and I can’t get that support  they say their tests say everything is fine
Any advice would be welcomed. Thank you
  • 11.97K
  • 933
  • 1.53K
Message 2 of 23
Re: Log on to work network suddenly not possible
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 24.81K
  • 1.43K
  • 3.16K
Message 3 of 23
Check that your IP hasn’t been inadvertently blocked on your works side
  • 8
Message 4 of 23
Hi Mike
I’ve been given a new laptop last week while they look at my old one ( we assumed it was a laptop issue) so the cable I have is the wrong one. I’ll pick up a cable from our IT team tomorrow and  try that. Will post again after that. Thank you
  • 8
Message 5 of 23
Will check that Gary- Thank you
  • 3.65K
  • 284
  • 513
Superfast
Message 6 of 23
To test the above theory put your HUB into modem mode and connect your laptop via ethernet.
You get a different public IP address when in modem mode.
To put it back into router mode either do a full reset (Pin hole press for 60 seconds) or access the HUB on http://192.168.100.1 instead of the usual http://192.168.0.1
  • 8
Message 7 of 23
Hi @MikeRobbo
i used a cable today and it shows as connected, secured but still wouldn’t link to my work network.
Paula
  • 3.65K
  • 284
  • 513
Superfast
Message 8 of 23
@PLG wrote:
Hi @MikeRobbo
Paula
Did you try my suggestion?
  • 8
Message 9 of 23
Hi I’m not very tech savvy. I’ve changed the WiFi hub to modem mode via the dashboard page and restarted it 10 mins ago. I’ve connected an Ethernet cable but my laptop is saying unidentified network no internet access.
not sure if I’ve plugged the Ethernet cable into the right socket. There are a choice of 4 all in use so I took one out and put the cable into that one.
  • 11.97K
  • 933
  • 1.53K
Message 10 of 23
In Modem Mode only one ethernet port on the Hub is active, remove ALL the ethernet cables then plug just the laptop in.
Mike Robinson
