Locked out of Virgin Media Hub
Hi, I am locked of the page shown in the picture. - screenshot below
It will not take any username or password I try, INCLUDING the correct one shown on the back of the hub.
Things I have tried:
1. Reset button for 30 seconds, followed by switching power to hub off for 60 seconds.
2. Reset button  for 30 seconds, leave system alone for 60 seconds
3. Switch entire thing off for 5 minutes at the power source.
Nothing resets the password to default, and it will not accept the default password - totally stuck !
  • 196
  • 44
  • 92
Re: Locked out of Virgin Media Hub
Hi Pete,
Please send me a PM with your account number and Area ref and I'll look at getting an updated hub sent to you
Harry
VM Field Tech
Send Me a PM!
If I've helped in any way, please give me Kudos and mark my response as a Helpful Answer once issue is resolved!
  • 15.44K
  • 1.62K
  • 2.64K
A pinhole reset on a Hub3 can be a bit problematic - so do it EXACTLY this way (not as the VM website says!).
With the Hub "on" disconnect any ethernet connections and push in the “reset pin” with the end of a paperclip/thin nail or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT restart the Hub after that. Leave it 5' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings one to access the Hub
  • 196
  • 44
  • 92
Hi John,
It looks like they have SH1 not SH3.
Harry
VM Field Tech
Send Me a PM!
  • 15.44K
  • 1.62K
  • 2.64K
@HarryVMTech wrote:
Hi John,
Ahhh... good spot 😀
sending now
Kind Regards
Pete
