  • 8
Location
Hi, I have recently installed the hub3 but when I log on and go onto sites that needs my location for local services, it says that I’m  in a completely different part of the country. Anyone know why?
  • 30.34K
  • 1.51K
  • 5.27K
Re: Location
IP addresses do not have locations. Any IP can be used anywhere in the world. 3rd party sites are used to try and map IP[ address but are never perfect.
So what you are seeing is normal and nothing to worry about
