Adz21
Message 1 of 7
Lights on, nobodies home
Having issues with my superhub 2, lights indicate that 5g and 2.4g is active but devices say no internet. Switching to 2.4g says password not recognised. I called the helpline yesterday and they said that due to covid there are no spare hubs available and because there is no issue with the connection into the house they cannot do anything? Not sure this is the best customer service? Other posters seem to have had this issue and were sent a new hub to try? Any chance I can have one too? Pretty please?
  • 22.53K
  • 2.41K
  • 4.03K
Message 2 of 7
Re: Lights on, nobodies home
Have you tried pinhole resetting the SH2 and see if that clears it?
The Hubs are in short supply at the moment (nothing to do with the standard Covid excuse mind) so are reluctant to swap unless the old Hub is faulty.
If you connect a device by ethernet cable are there any issues then - or is it just wifi?
Adz21
Message 3 of 7
thanks, as soon as it goes again I’ll give it a try and let you know.
Adz21
Message 4 of 7
Right so I’ve reset (twice now) seems to last approx 90mins before dropping out again and requiring another reset. However if hardwired to a laptop it’s fine, so it appears to be the Wi-fi transmission itself, any other clues? TIA
  • 22.53K
  • 2.41K
  • 4.03K
Message 5 of 7
As its a SH2 you are due a free upgrade to the Hub3 anyway so worth trying that again first. But as you have discovered, VM are loathe to just give them out to customers with a functional SH2 - so your best option is to call it in as a fault and tell them its faulty and see if that gets you anywhere.
Call it in on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Calling at 08.00 midweek (09.00 Sun) is the best time to get through quickly. Although some people are still reporting getting through fine at other times with no long waits
I still use the SH2 but always have had it in modem mode with my own router and wireless equipment and that still works perfectly - you could consider that as your ethernet connections are still all fine
Adz21
Message 6 of 7
Top man, thank you sir.
Molly_G
  • 405
  • 23
  • 48
Message 7 of 7
Hi @Adz21
Thanks for your post last week and welcome to the forums!
I'm sorry you were experiencing WiFi issues recently. I've just taken a quick look into the account using the details you've registered to forums with and can see that you've followed John's advice and managed to get a Hub 3 on the way successfully. Hope you see the improvement after this upgrade 🙂
Feel free to drop back if you need any help or advice in the future!
Molly_G
