Latency issues
mellatron
Had an ongoing issue in our area for a while, high latency making working from home impossible. From what I understand we have a Sync issue between the hub and the street cabinet resulting in partial service.
Hoping a virgin team  member will see this and send an engineer out to fix the issue.
Acquired Downstream Channel(Hz)139000000Locked
Ranged Upstream Channel(Hz)49600000Ranged
Provisioning StateOnlineOperational
11390000006.141QAM 2561
21470000005.841QAM 2562
31550000005.741QAM 2563
41630000005.441QAM 2564
51710000005.141QAM 2565
6179000000541QAM 2566
71870000004.841QAM 2567
81950000004.541QAM 2568
92030000004.241QAM 2569
102110000003.941QAM 25610
112190000003.841QAM 25611
122270000003.941QAM 25612
132350000003.841QAM 25613
142430000003.441QAM 25614
152510000003.441QAM 25615
162590000003.240QAM 25616
172670000003.241QAM 25617
182750000003.140QAM 25618
19283000000340QAM 25619
202910000003.241QAM 25620
212990000003.441QAM 25621
223070000003.741QAM 25622
233150000003.741QAM 25623
243230000003.741QAM 25624
253310000003.541QAM 25625
263390000003.441QAM 25626
273470000003.641QAM 25627
283550000003.541QAM 25628
293630000003.841QAM 25629
303710000003.941QAM 25630
313790000003.941QAM 25631
1Locked41267908
2Locked4118616
3Locked4115091066
4Locked412052623
5Locked412085562
6Locked411715164
7Locked411888162
8Locked411664153
9Locked411553152
10Locked411453438
11Locked411287175
12Locked411251132
13Locked411105142
14Locked411239397
15Locked41931351
16Locked401248435
17Locked411273518
18Locked401268515
19Locked401198139
20Locked411228509
21Locked41965521
22Locked41702450
23Locked41642470
24Locked41636452
25Locked41767517
26Locked41953603
27Locked411154855
28Locked411125506
29Locked411205606
30Locked411082834
31Locked411027615
04960000044.35120QAM 641
14310000043.35120QAM 642
23660000043.35120QAM 643
33010000043.35120QAM 644
42360000042.85120QAM 645
0ATDMA01250
1ATDMA01210
2ATDMA01200
3ATDMA01200
4ATDMA012721
General Configuration
Network accessMaximum Number of CPEsBaseline PrivacyDOCSIS ModeConfig file
Allowed
1
Enabled
3.1
834ncxv9873254k;fg87dsfd;
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
480
1200000450 bps
42600bytes
0 bps
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
479
110000274 bps
42600bytes
0 bps
42600bytes
Best Effort
20-08-2023 15:33:02criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 15:32:30errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 11:12:03criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 11:12:01warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 11:11:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 11:11:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:58:00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:57:00warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:56:03criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:56:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:42:01criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:42:00warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:41:02criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:41:00warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-08-2023 10:25:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-08-2023 20:04:04warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-08-2023 20:04:04noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-08-2023 18:56:52warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-08-2023 18:56:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-08-2023 18:51:05warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-08-2023 18:51:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-08-2023 18:40:59noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-08-2023 18:40:59warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-08-2023 15:32:28errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-08-2023 23:23:12warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-08-2023 23:07:43criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-08-2023 23:07:04criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-08-2023 15:32:25errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-08-2023 03:57:01criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-08-2023 03:53:47criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-08-2023 03:52:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-08-2023 03:32:24errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
My Broadband Ping - Hub 5
5 REPLIES 5
Legend
The Downstream Errors across all channels is the stand out concern. If error figures are still rising there is a local noise issue.
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
Once the test begins click on: Run full test to see all the stats inc Latency / Jitter / Packet Loss.
mellatron
Annoyingly Sam Knows looks fine:
Download Mbps
1144
Upload Mbps
101
Latency ms
9.84
Jitter ms
1.07
Packet loss %
0.0
However my BQM reflects the issues we are having with latency:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a53f91ce7c2169b23d0af29f0dfa881743...
Hey mellatron,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your connection at the moment, I can see that the area issues that were affecting you have now been resolved.
I have looked into your individual connection and can see that there is an issue with your upstream channels that will need a technician visit to resolve, I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment. Please look out for the private message and we can get started.
Kind Regards,
Steven_L
Legend
Both Realspeed and BQM traffic follow the same journey from the home to the public internet.
So what is BQM showing, latency on their end or en-route ? We can not tell from the graph.
As I read it, BQM shows the latency spikes over a 24 hour period compared to just a snap shot from Sam knows at the time of test.
