Latency and Timing Out Issues
Gary333
Up to speed
I'm having issues with the connection timing out / or going very slowly when trying to access web pages. My kids are saying their ping and latency is terrible. Phones etc just seem to be working, then give up. When I do a speed test it's less obvious there is a problem though. This issues seems to come and go. If I reset the router it fixes it for a while (maybe a day or two) but then it comes back.
I have a 3dbmv attenuator already on my Hub 4 and here are the power levels. It does seem to get worse as the power level's increase.
Is it normal to have some channels in the 5dbmv range, but others in the 9dbmv range?
A while ago I asked an engineer if he could move to a lower powered tap in the cabinet to see if this might help (as i used to get power levels very close to each other around 0dbmv and the connection was stable for well over a year). He came back and said he couldn't do anything, but never said why.
For reference I am c.128m away from the cabinet, so i am surprised the power levels are still so high. In my last house I used to get similar power levels but was the first house next to the cabinet at <30metres.
DOWNSTREAM
11390000009.00000040.366287QAM2561
21470000008.80000340.366287QAM2562
31550000009.19999740.366287QAM2563
41630000008.69999740.366287QAM2564
51710000008.30000340.366287QAM2565
61790000007.90000240.366287QAM2566
71870000008.00000040.946209QAM2567
81950000007.69999740.946209QAM2568
92030000007.30000340.366287QAM2569
102110000006.80000340.366287QAM25610
112190000006.30000338.983261QAM25611
122270000006.19999740.366287QAM25612
132350000006.50000038.983261QAM25613
142430000006.80000340.366287QAM25614
152510000006.90000240.366287QAM25615
162590000007.19999740.366287QAM25616
172670000006.50000040.366287QAM25617
182750000005.90000240.366287QAM25618
192830000006.19999740.366287QAM25619
202910000006.40000240.366287QAM25620
212990000007.19999740.366287QAM25621
223070000006.90000240.366287QAM25622
233150000006.59999840.366287QAM25623
243230000006.50000040.366287QAM25624
253310000006.50000040.366287QAM25625
263390000006.80000340.366287QAM25626
273470000006.59999840.946209QAM25627
283550000006.50000040.366287QAM25628
293630000006.09999838.983261QAM25629
303710000005.50000040.366287QAM25630
313790000005.90000240.366287QAM25631
UPSTREAM
12360000047.5205995120 KSym/sec32QAM13
23010000047.5205995120 KSym/sec64QAM12
33660000048.0205995120 KSym/sec64QAM11
44310000048.0205995120 KSym/sec64QAM10
54960000048.5205995120 KSym/sec64QAM9
6 REPLIES 6
Problems by wifi?
Joseph_B
Hey @Gary333,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you have been having this issue, having a look into our systems I can see you would benefit from having a technician sent out to assess the situation. For me to do so I will need to confirm some information from you in a quick private message.
Joe
Gary333
Up to speed
Thanks Joe. I have responded to the PM. Cheers
Gary333
Up to speed
These problems are back again with vengeance. I have tried swapping back to the Hub 4 and it's even worse than when that's in modem mode.
I have reset the Hub 4.0 multiple times (both holding for 15 secs and 60 secs as there seems to be no clear cut answer on how long to hold the reset button).
I've tried changing the cable out for the one in the quick start guide. I've also tried it without the attenuator (just in case that was faulty), however, that was terrible and gave 50% packet loss so put it back on.
When VM came out last time he says "there's no errors showing in the router table" and can't see anything wrong. He's right, there isn't then and isn't now any Pre or Post RS errors.
The issue seems worst when this upload channel drops to 32QAM and very bad when it drops to 16QAM.
22360000047.0205995120 KSym/sec32QAM13
Here my current full stats:
11390000009.50000040.366287QAM2561
21470000009.30000340.946209QAM2562
31550000009.59999840.946209QAM2563
41630000009.09999840.946209QAM2564
51710000008.80000340.946209QAM2565
61790000008.59999840.946209QAM2566
71870000008.50000040.946209QAM2567
81950000008.09999840.946209QAM2568
92030000008.00000040.946209QAM2569
102110000007.69999740.946209QAM25610
112190000007.19999740.946209QAM25611
122270000006.69999740.946209QAM25612
132350000007.09999840.366287QAM25613
142430000007.40000240.366287QAM25614
152510000007.40000240.366287QAM25615
162590000007.90000240.366287QAM25616
172670000007.19999740.366287QAM25617
182750000006.40000240.946209QAM25618
192830000006.90000240.366287QAM25619
202910000007.19999740.366287QAM25620
212990000007.50000040.366287QAM25621
223070000007.59999840.366287QAM25622
233150000007.50000040.366287QAM25623
243230000007.19999740.946209QAM25624
253310000007.30000340.946209QAM25625
263390000007.69999740.366287QAM25626
273470000007.90000240.366287QAM25627
283550000007.50000040.366287QAM25628
293630000007.30000340.366287QAM25629
303710000006.90000240.946209QAM25630
313790000006.69999740.366287QAM25631
14310000047.5205995120 KSym/sec64QAM10
33010000047.5205995120 KSym/sec64QAM12
43660000047.5205995120 KSym/sec64QAM11
54960000048.0205995120 KSym/sec64QAM9
So problems by wifi?
Hi Gary333 👋 Welcome back to the community! Thank you for posting.
Sorry to hear you are having some issues with your connection.
Having had a look for you, there are no issues happening in the local area that would be affecting your connection. (There are no issues with the data coming from the cabinet currently).
There are a couple of disconnections showing on the hub in the last few days, however it is also running in Modem mode which will be affecting our ability to troubleshoot and offer further support. If you can please pop the hub back into router mode so we can run further testing, and I will send you a PM to offer some help and support with this!
You can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
Molly
