Laptop's Not connect back to Hub when rebooted
jvoce
The issue is that started about 3 weeks ago.  Reboot my laptop then wont connect back to the hub, this is connected via ethernet cable, the same goes for my other 2 laptops, they are connected by Wi-Fi, reboot them and they wont connect back to Wi-Fi.  The only way to get them to connect is to switch the hub on and off.  Then they all connect ok.  I have had 2 engineers out, as power levels were down and i had a new hub replaced.  But still the same issue, any ideas?
cheers
10 REPLIES 10
Legend
Have the Hub signal levels been corrected to the point where the current Hub starts up and gets to a normal connected state ?
Hub Signal Level Checks
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status"     Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream
Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels.  Seeing QAM 32/16 or QPSK is a current service noise fault.
jvoce
downstream
1 331000000 2 38 256 qam 25
2 203000000 1.2 37 256 qam 9
3 211000000 1 37 256 qam 10
4 219000000 1 37 256 qam 11
5 227000000 1 37 256 qam 12
6 235000000 0.7 37 256 qam 13
7 243000000 1 38 256 qam 14
8 251000000 1.2 38 256 qam 15
9 259000000 1.2 37 256 qam 16
10 267000000 1.2 38 256 qam 17
11 275000000 1.2 38 256 qam 18
12 283000000 1.4 37 256 qam 19
13 291000000 1.7 38 256 qam 20
14 299000000 2.2 37 256 qam 21
15 307000000 2 38 256 qam 22
16 315000000 2 38 256 qam 23
17 323000000 1.7 38 256 qam 24
18 339000000 2 37 256 qam 26
19 347000000 2 38 256 qam 27
20 355000000 1.9 38 256 qam 28
21 363000000 1.2 38 256 qam 29
22 371000000 1.7 38 256 qam 30
23 379000000 1.7 38 256 qam 31
24 387000000 1.7 38 256 qam 32
1 Locked 38.9 10 0
2 Locked 37.6 9 0
3 Locked 37.6 10 0
4 Locked 37.6 11 0
5 Locked 37.6 12 0
6 Locked 37.6 14 0
7 Locked 38.6 10 0
8 Locked 38.6 10 0
9 Locked 37.6 15 0
10 Locked 38.6 20 0
11 Locked 38.6 16 0
12 Locked 37.6 15 0
13 Locked 38.6 6 0
14 Locked 37.6 10 0
15 Locked 38.6 9 0
16 Locked 38.6 10 0
17 Locked 38.6 14 0
18 Locked 37.6 10 0
19 Locked 38.6 12 0
20 Locked 38.6 13 0
21 Locked 38.9 13 0
22 Locked 38.6 11 0
23 Locked 38.6 14 0
24 Locked 38.6 4 0
upstream
1 49600012 48.8 5120 64 qam 1
2 23600000 48.8 5120 64 qam 5
3 30099991 48.8 5120 64 qam 4
4 36599986 48.8 5120 64 qam 3
5 43100024 48.8 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
Legend
2 Hubs and 3 laptop's that all fail to work well with either Hub.
But  no mentions of any other connectivity issues with TVs / mobiles / Kindles etc.
What happened 3 weeks ago to all the laptops as they appear to be the items having the problems ?
New security software or VPNs installed etc ... ?
jvoce
Tv's are ok, mobiles sometimes times out connected to wi-fi, quicker sometimes to switch it off on the phone and go 4g, only change to the hub is cctv added.  But unplugged this from the hub and same issue.  No software updates, just usual windows updates
jvoce
got one laptop connected to the hub, but giving message "No internet, secured"  other is connected ok
Legend
This is what happens when Wi-Fi Pausing / MAC Filtering has been used on any Hub.
This can also happen on a Hub 5 if the Hub's DHCP server fails.
jvoce
Hi, no probs, had to reboot, still no connectivity to wifi, have to restart router to connect
Hi jvoce,
We're sorry to hear you're having issues with connecting to the hub. As mentioned by Client62, it sounds as though the WiFi is being paused. Please can to perform a full pin hole reset on the hub. You can do this by holding the reset button in for a timed 40 seconds. Leave the hub reboot itself and this should clear any pauses.
Keep us posted on how you get on.
Kath_F
jvoce
its a brand new router, surely shouldn't be doing this already?
cheers
