  • 9
Message 1 of 9
Lan router settings.
Hi, I need information on setting up an add on Lan router (not wifi) to my Virginmedia 3 router.
Obviously my vm router has to be in modem mode.
I have heard that virginmedia doesn't use PPPOE and I have to use DHCP. Is this correct? If so what if my add on router doesn't have a DHCP option from the drop down box (just pppoe & ipoe).
Some have said that I need to have a static ip. Is this correct?
Do I have to add primary 194.168.4.100 & secondary 194.168.8.100 DNS settings?
Wan  configuration screen, do I need to add:
ip address? - static ip? - subnetmask? - gatway ip address?
Thank you for any help you can give, as I have spent days on this and have got nowhere.
  • 19.65K
  • 1.72K
  • 4.29K
Message 2 of 9
Re: Lan router settings.
well if using modem mode, the device attached will request an IP address via DHCP.
Some have said that I need to have a static ip. Is this correct? No, also not possible on residential accounts
when you attach your own router, it should make a new DHCP lease request to the hub, if doesn't turn both hub and 3rd party router, turn on hub wait about 2 minutes, and then the other router, this should make the DHCP lease and get the IP address, default gateway etc automatically
  • 14.77K
  • 622
  • 1.42K
Message 3 of 9
Their should be a DHCP option when you select IPoE
  • 9
Message 4 of 9
The router that I was trying to use was a ZYXEL VMG3925-B10C, this all singing all dancing £125 confusing pile of poop doesn't seem to have DHCP.
So I bought a brand new & sealed 2004 D-Link DI524 which cost £8 inc p&p.
This worked like a charm, hooked it up, clicked the wizard button, and in just a few minutes it was up and running.
My only very small gripe is it's only 10/100mbps and doesn't have 1000mbps, but as my broadband connection is 100meg it's a perfect match. Right?
Thank you for your help, I appreciate it
  • 24.87K
  • 1.43K
  • 3.16K
Message 5 of 9
It does support DHCP - https://www.zyxel.com/uk/en/products_services/Dual-Band-Wireless-AC-N-VDSL2-Combo-WAN-Gigabit-Gatewa...
With a router with 100Mbps ports you’ll get maybe 90Mbps max.
  • 9
Message 6 of 9
I see from the user manual that it's supposed to have a wizard; lol.
90mbps ooh heaven! For years I had 1mps with Sky who wouldn't help at all, and the 4mbps with EE who did help. 90mbps pure luxury 🙂
Thanks for your help.
  • 1.69K
  • 93
  • 234
Superfast
Message 7 of 9
that d-link you've bought is junk, it's not even worth £8.
My Broadband Ping - spgray
  • 9
Message 8 of 9
Why?
I don't want wifi (at all), it works more or less straight out of the box, at a speed I'm well happy with and it doesn't look like a drone.
Security would be the only issue as it is old.
If I should know something please churp up. 🙂
  • 1.69K
  • 93
  • 234
Superfast
Message 9 of 9
it's junk, that's pretty much everything you need to know about it
