on 01-07-2023 14:48
Past couple of weeks I've been getting bad lag spikes on my VM home broadband and my housemate has reported the same issue, where the internet completely freezes up for 5-30 seconds meaning we are getting frequent lag on streams, gaming etc. Both our computers are wired into the hub so it's not a wi-fi issue.
I have included a BQM here if it is useful, could anybody advise on how to fix this please?
03-07-2023 10:10 - edited 03-07-2023 10:10
After getting the same lag/delays on the VM broadband last night I plugged my phone into my PC and used the 4G internet instead and had no issues at all for several hours online so I'm fairly certain the issue is with the VM connection or hub.
Here is the link you asked for:
on 03-07-2023 10:16
Hi user979420,
Thanks for the link. There will always be some latency on your BQM; the graph is looking very stable apart from the disconnection logged just after 2pm. However could this be from when the Hub was rebooted?
Are you experiencing issues across wired devices too?
Everything on this end is within the normal parameters and your BQM looks fine, so I am struggling to locate an issue on the network.
Thank you
on 03-07-2023 11:33
Yes both PCs are wired in after having separate issues with wi fi dropping out. My contract is up for renewal next month so if I can't get this issue fixed I'll be looking to leave VM as the connection isn't fit for purpose right now. I'm using my 4g again today and it's been flawless so there is definitely an issue somewhere with the VM service.
on 03-07-2023 12:03
Hi user979420,
I'm sorry to hear you feel this way and I can appreciate the frustrations with this, we're doing our best to try and get to the bottom of it.
Just to clarify, after having wired in your PCs, are you still experiencing the issues?
on 03-07-2023 13:35
Yes it happens several times per hour where the connection lags/freezes up and nothing will work for about 5-30seconds only when I'm on VM internet it doesn't happen on my o2 4g connection
on 03-07-2023 14:02
Hi user979420,
Thank you. I appreciate you said that you're sure that all the cables are secure, however I would advise to please just check that they are 'finger tight' as any lose connections can cause signal imbalances and have a negative effect on the connection. Your live BQM is still showing very stable and no disconnections logged, so this would indicate an issue possibly located in the property.
on 03-07-2023 15:29
@Beth_G wrote:Your live BQM is still showing very stable and no disconnections logged, so this would indicate an issue possibly located in the property.
Means nothing when BQM goes to hub and your not testing Ethernet/wifi with the router mode doing NAT.
05-07-2023 19:00 - edited 05-07-2023 19:01
Yes the cables are and have been plugged in correctly. I've been using my 4g since monday instead which works perfectly all day and night without lag spikes, have just swapped back to using my VM and it's just as bad as it was with frequent lag still.
on 05-07-2023 21:54
Put hub in modem mode with a PC and see what its like
on 06-07-2023 12:03
Thank you for confirming this.
I have taken a look and everything is look normal on our side with some good levels.
How has it been over night? Thanks
Matt - Forum Team
New around here?
