Just joined
Keep losing connection with WiFi
all my devices keep losing connection to Wifi. First it was showing an issue with broad band in the area then you said you are sending a technician on monday now it got cancelled. Issue still exists the broadband have been playing up last few weeks. I'm tired of trying to resolve this its so diffcult to get in touch with virgin. For £50 a month its a laughable customer service ...
  • 12.3K
  • 952
  • 1.58K
Re: Keep losing connection with WiFi
Is it devices losing wi-fi connection with the Hub or Hub losing the WAN connection.
What is your connection like using a direct connection using a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Anonymous
Not applicable
Just to clarify are devices (wired and wireless) losing connection? (if so its the WAN/Virgin Network issue or possibly the hub), if its just wired, then its a LAN/WLAN issue, ie one that is in your home.
