Message 1 of 5
Keep losing connection but no light comes on
So from last night the router loses connection but no lights comes on, only after restarting the problem is fixed for about an hour and it happens again and i have to restart it. Does anyone have the same issue and know a fix or it's just vm issue that needs to be fixed?
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 5
Re: Keep losing connection but no light comes on
There’s a national outage currently...
https://www.virginmedia.com/help/outage
Message 3 of 5
I am aware of the outage but should the light not come on if there is no connection? There seem to be nothing unusual on the logs aswell, Thanks for the answer i think i will wait couple of days if the problem is fixed!
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 5
Reboot the hub
  • 53
  • 6
Dialled in
Message 5 of 5
Your hub does have a connection to Virgin - the outage problem is within Virgin's (and other ISP's) connection to the internet.
From the perspective of your super hub you still have a working connection because it can talk to all the Virgin kit just fine.
