ItsOnlyDanO
Issues with Superhub 3.0
Hi there
I've recently been having issues with my superhub, the two main ones have been the connection seemingly constantly varying in speed, often with it dropping out for a couple of seconds before seemingly working again.
It's also been a fair bit hotter than usual, It's not something I usually notice with it but it is something I've picked up on.
From what I've seen posting downstream/upstream seems to be the best way to figure out what the issues are with it (I've no idea but I hope someone on here does!), so I'll post them below...
11867500005.940256 qam7
21947500005.340256 qam8
32027500005.640256 qam9
42107500005.838256 qam10
52187500005.940256 qam11
62267500005.840256 qam12
72347500005.840256 qam13
82427500005.640256 qam14
92507500005.640256 qam15
102587500005.940256 qam16
112667500006.138256 qam17
122747500006.138256 qam18
132827500006.540256 qam19
142907500006.338256 qam20
152987500006.638256 qam21
16306750000740256 qam22
17314750000740256 qam23
18322750000740256 qam24
194027500007.540256 qam25
204107500007.538256 qam26
214187500007.540256 qam27
224267500007.638256 qam28
234347500007.838256 qam29
244427500007.938256 qam30
1Locked40.3175248132941
2Locked40.3213960115683
3Locked40.3184538108818
4Locked38.9178825101273
5Locked40.918898091421
6Locked40.323081683626
7Locked40.325566777996
8Locked40.326193472229
9Locked40.325084767602
10Locked40.322878464881
11Locked38.621137465123
12Locked38.919173066274
13Locked40.319772466538
14Locked38.922922368924
15Locked38.921561769073
16Locked40.318354369602
17Locked40.317085773978
18Locked40.316079272112
19Locked40.317908454672
20Locked38.919518552176
21Locked40.319090849082
22Locked38.921451145911
23Locked38.920697844704
24Locked38.920199342990
Upstream next:
1394004264.65512032 qam4
2602998164.375512032 qam1
3537001124.75512032 qam2
4461998884.625512032 qam3
3ATDMA0000
4ATDMA0000
And finally here's the network log:
12/11/2019 19:47:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2019 19:47:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2019 19:47:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2019 19:47:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2019 19:47:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2019 19:27:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks for any help in advance!
  • 1.71K
  • 241
  • 372
DJ_Shadow1966
Super solver
Re: Issues with Superhub 3.0
Hello
Thank for joining in on the forum, we will try the best to get your issue resolved.
Hub 3.0 as they are will tell you if it is hot, i.e. the Base Light will turn red.
Looking at your stats they are all within specs, but you seem to having lots of post RS Errors, when was the hub last turned off.
Can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or UN-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
ItsOnlyDanO
I've had a look at the connections and they all look ok to me, so I'll try out the broadband monitor and see if I can figure out what's going from that.
