Message 1 of 9
Issues with Super hub 1
My old superhub 1 keeps dropping the wifi connection (it used to be OK). Is there any way to get a replacement router? There's also wifi dead spots upstairs. I can't seem to get through on the chatbot
Tags (2)
  • 1.66K
  • 85
  • 129
Message 2 of 9
Re: Issues with Super hub 1
Hi speleonut,
Thank you for your post and welcome to the forums.
Sorry to hear you've been having this problem. Upon checking your account, everything seems fine this side - it has been online for quite a while, if you're able to reboot that? In terms of the WiFi connection, can you expand on what happens exactly? Do you have any wired devices connected?
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
  • 17.57K
  • 1.85K
  • 3.06K
Message 3 of 9
Its an SH1 ! It doesn't even do simultaneous 2.4 & 5 GHz wifi. It belongs at the recycling centre.
Put the customer out of their misery and just replace it for free.
  • 1.66K
  • 85
  • 129
Message 4 of 9
@jbrennand thanks for that 🙂
I will wait for the speleonut to come back first - cheers.
  • 17.57K
  • 1.85K
  • 3.06K
Message 5 of 9
Pretty sure they will be "eligible"
https://www.virginmedia.com/shop/hub-swap.html?buspart=uk_app_connect2_hubswap
  • 1.66K
  • 85
  • 129
Message 6 of 9
Spot on!
Cheers.
Message 7 of 9
Thanks for the reply.
Yes I have a wired connection to the home PC which is ok 95% of the time but the 5% of the time is very inconvenient.
There's 2 issues with the WiFi. The most annoying is that ever couple of weeks or so it will go through a period of 2-3 days where it won't let WiFi devices connect. This necessitates a series of router reboots until it is working again. It can take a couple of hours spread over a day or two to get everything back again.
The other problem is it is slow when more than a couple of us are using the WiFi for streaming, making it almost impossible for more than 2 people to watch smoothly.
Range isn't great either with vey low signal at the top of the house
I tried the upgrade link but it doesn't work 😞
  • 1.66K
  • 85
  • 129
Message 8 of 9
I will pop you over a private message 🙂
Cheers.
  • 1.66K
  • 85
  • 129
Message 9 of 9
Not a problem at all - glad I could help 🙂
Cheers.
