Message 1 of 7
Issues connecting to services/websites
Over the last day or two I've been having issues connecting to a couple of services and websites. The main ones being Disney +, the bord gais website and Destiny 2 servers on the PlayStation 4. I've tried restarting the devices and router, as well as uninstalling and reinstalling the game and app but haven't had any luck fixing it. Is there any solution for this?
Thanks.
  • 5.85K
  • 1.1K
  • 1.54K
Message 2 of 7
Re: Issues connecting to services/websites
Hello
II know that at least playstation use a service to check your reputation if you check on https://www.akamai.com/us/en/clientrep-lookup/ and if it comes up as "bad reputation" then it will down to Sony to resolve that.
The other sites you mention may also being using the same system to block bad reputation scores.
Regards Mike
Message 3 of 7
I had a look at the link and it says I don't have a bad risk score so it doesn't seem to be that. Thanks for the response.
  • 24.57K
  • 1.41K
  • 3.12K
Message 4 of 7
Is this happening over a wired or wireless connection?
Message 5 of 7
Both. I have PlayStation connected via ethernet and my phone and laptop on the wi-fi. I have Disney + on the PS4 and my phone and get the same error message (error code 83) on both
  • 11.7K
  • 913
  • 1.51K
Message 6 of 7
What is the laptop connection like when using an ethernet cable ?
Can you post the URLs of the sites you are having problems with.
Mike Robinson
Anonymous
Not applicable
Message 7 of 7
Take a read of this, it might help. https://www.androidcentral.com/error-83-disney-plus
