@ImWai wrote:
Hi community members + forum teams,
I am struggling to get my Philips Hue Bridge (v2) connected and seeking help please.
Situation:
- I'm using the Virgin Hub 4 as is (not in modem mode)
- the Philips Hue Bridge is connected to power and Hub 4 via ethernet cable
- other devices connected via ethernet ports seems to function fine (for example: Hive hub)
- I can see within 192.168.0.1 that 'Philips-hue' is showing under Ethernet Connected devices
- within the Philips Hue app, I can't seem to discover the Philips Hue Bridge
I have done:
- reset the Philips Hue Bridge
- customised SSID names and passwords to split out 2.4 GHz and 5 GHz wifi
- disabled 5 GHz
- disabled guest wifi
- set 2.4 GHz channel to manual, channel 1
- tried changing WPA2-Personal and WPA-WPA2-Personal settings
- tried using a different ethernet port and ethernet cable
- contacted Philips Hue support
- who suggested disabling Access Point (AP) Isolation, or Client Isolation, or Guest Mode, on my router
Does anybody know + can someone help?
How can I disable AP?
Or what can I do to connect my Bridge to the app?
Thanks for reading !
I'm not sure why you have changed any of your WiFi settings (though setting the SSID or splitting the bands is fine if that's what you want to do, for unrelated reasons).
As far as I know the only WiFi involved in the set up should be for your phone to connect to the Virgin Hub. Does your phone connect to the Virgin hub, and the internet, okay?
AFAIK the Philips Hue Bridge uses Zigbee (a different wireless system) to communicate with the individual bulbs. It obtains its connection to your hub, and the internet, via the Ethernet cable.
Access Point Isolation is to separate clients (devices) on your home network from one another, usually for security reasons (so a child can't see your computer data for example). I can't be sure but doubt it's enabled at all on the VM hub (other than if you were using your phone on the guest network, which is separated off (so visitors can use the internet but not connect to your internal network).
You don't want to 'disable your AP' as that would mean none of your devices would be able to connect to the internet via WiFi !
I'm not sure as to why your Philips app isn't picking up the bridge - but I would put your VM hub back to normal and start again. It seems you've got confused somewhere. Go back to Philips or post again here if it still doesn't work.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
