on 06-01-2021 15:32
I know this is possible on other routers, but is there a way to limit speed to a device or in general using the Hub 3? Many other routers allow you to limit the speed to individual devices and I have been unable to find a setting on the Hub 3.
Is there a way to do this manually or would it require purchasing a more advanced router and using the Hub in modem mode, thanks.
on 06-01-2021 15:38
Not on a Hub 3 that I'm aware of. But what are you trying to achieve? Most of us would prefer faster speeds rather than slower, if this is about "preferring" a specific device, then most decent routers and mesh systems offer some form of Quality of Service (QoS) capability, although even that isn't necessarily a speed limiter as such.
on 06-01-2021 16:12
@Andrew-G wrote:But what are you trying to achieve?
Dunno about OP but I’m certainly considering varying levels of packet loss as a modern day version of grounding as my kids get a bit older 😂
on 07-01-2021 07:24
Almost any modern router or mesh has a control app that allows blocking of selected devices at the press of a touchscreen (even the VN Connect app allows that, I believe). Not quite the same as limiting speed or even inducing a bit of packet loss to make the blighters give up!
