on 10-08-2023 16:54
Hi, My Iphone is having trouble with connecting to Virgin Wifi. If i reset it i can connect but as soon as the phone goes to sleep it loses it and uses 4G, turning off mobile data also does not help. I have zero issues in any other wifi areas and my wife's identical iphone connects to our Virgin hub along with all the other devices at home. I am up to date with IOS etc. Any help on this one please?
on 11-08-2023 08:05
Hey huesey1974, thank you for reaching out and a warm welcome to the community I am sorry to hear this.
I have taken a look and your WIFI is looking great, the levels are very good.
Do all the other devices connect no problem like your wifes phone?
If this is the case there could be an issue with the actual phone. Cheers
Matt - Forum Team
New around here?
on 11-08-2023 16:15
See if anything in these similar issues helps fix yours...
No connectivity on Apple kit may be a MAC filtering issue for Apple devices - see if this has the solution for you….
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-iPhone-Apple-MacBook-amp-HP-Pr...
_____________________________
After a MacOS/iOS update, it may auto turn on Automatic Proxy Discovery for all Wi-Fi networks - so turn it off in network settings as per message 7. In iOs go to Settings>WiFi> tap the blue”I” icon and scroll down and make sure Configure Proxy/‘ is set to off - also that Configure DNS and Configure IP are set to automatic
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-5-macOS-Monterey/td-p/4885920
Cant connect as password is incorrect on iPhone (& Andrex)……. this sorted it…
Just moving the SIM sorted it here....
on 28-08-2023 07:14
Its only my phone that has this issue, it works on any other WIFI with no issues though. only on my newly installed Virgin system.
on 28-08-2023 08:14
Turns out Virgin media does not like my VPN being on. Works when turned off.
28-08-2023 08:25 - edited 28-08-2023 08:26
From the Virgin Media account , Disable Child Safe in order to allow a VPN to work.
