Almpan
Ip address 192.168.0.1 why doesn’t connect me saying wrong password whet i type the correct one
Why doesn’t connect me on ip address saying wrong password when I type the correct one
Tags (1)
  • 1.95K
  • 125
  • 457
Super solver
Re: Ip address 192.168.0.1 why doesn’t connect me saying wrong password whet i type the correct one
Unless the Hub's password has been changed, this could be the (known if not common) problem of the Hub having corrupted the password info.
A factory reset of the Hub might be the only option to attempt to regain access.
Regardless of VM notes on a reset, the RESET button needs to be pressed for a full 60 seconds to trigger the factory reset and then just leave the Hub to reset and restart.
This will revert the HUB to the initial WiFi SSID / Passwords. If the Hub's password still does not work a Hub defect will have to be reported to Support.
  • 15.92K
  • 2.11K
  • 5K
Hi @Almpan
You need to use the Settings password, not the wifi password to  log into 192.168.0.1
If you've enabled Modem Mode on the hub you'll need to use 192.168.100.1 instead.
Dave
Love, love and love, forever - Pele
