Internet works on ethernet not wifi
Hi I have ethernet cable connected and Internet through that. Also TV working but no wifi connection to other devices.
  • 6.92K
  • 511
  • 898
Legend
Re: Internet works on ethernet not wifi
Is Wi-Fi enabled in the Hub ?
VM Hubs are renowned for their poor Wi-Fi, and at the best of times Wi-Fi is a fickle beast that can be affected by numerous things such as distance from the Hub,  building construction, other electronic devices, neighbouring Wi-Fi, basically all sorts.
VM supply to the Hub, after the Hub it is up to you.
Many on here, myself included advocate the use of a third party Gigabit capable Wi-Fi router or Mesh system.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Hi Mike
Many thanks for your reply. Wifi on and no previous issues with wifi although we do have tp links as I have to have a wired connection for work. I turned it off over night (put it on the naughty step!) and all seems ok now.
