Anno60
Internet speed
I have 200 speed with Virgin. I did check this morning and my speeds are as follows  says ya average download is 38.4 , is this good or bad , I don’t really understand the numbers .
Thank you
g0akc
  • 569
  • 59
  • 118
Rising star
Re: Internet speed
How did you check?  What site, and with what equipment/device?
How were you connected to the Hub?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
Anno60
Re: Internet speed
Power clean on iPhone 6 , were not on an ethernet cable as router upstairs .
Thanks for reply
  • 20.51K
  • 2.18K
  • 3.62K
Re: Internet speed
What Hub model is it? If a Hub3 try this as for top speeds you have to be on the 5GHz band
Go into the Hub3 settings. Type in  http://192.168.0.1  into your web browser’s url box and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless>smart wifi - tick the disable “channel optimisation” box and save settings.  Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's.  Just change 'em to whatever you like and something that will differentiate them (e.g - xxxxx_2 & xxxxx_5) -- use the same password for simplicity,  Then, apply settings and restart the Hub.  Your 2 wifi networks will now be clearly separated - and you can then select the network you want to connect to individually from the "available networks" list on each device.
Note all your wifi devices will need re-connecting to the new SSID's and passwords.
5 GHz is allways better and faster and subject to less interference (and is better for all iDevices ) than the 2.4 one - although this one has the better "range" and some older/cheaper/dumber devices can only use this one.
You should also use a wifi analyser App to check which 2.4 channels are being heavily used around you and move yours to one of numbers 1,6,11 that is least so, but it wont help if there is other interference.
See if these changes help - you will lose any “seamless roaming” benefits but it may not matter and you can always change the settings back by doing a " pinhole factory reset " if you prefer the way it was - or it doesn’t help.
