Internet speed up and down like a yoyo
My internet is up and down like a yoyo, one minute its 19Mbps the next its 80Mbps. Usually its at the lower end though, and considering i pay for 200 it's a nightmare. Must of reset my hub about 20 times in the past week trying to get it working again but no change. Any suggestions would be hugely appreciated
  • 8
Re: Internet speed up and down like a yoyo
hi
try making sure all your connection tight. You could also try login into your modem, 192.168.0.1 and your password is the 8 numbers on the bottom of your hub. then go onto your wifi settings and change your channels and disable your smart wifi settings.
if this doesnt help then you can private message with your account number and area code so i can run a couple test for you
thanks
  • 20.96K
  • 1.13K
  • 2.7K
How are you speedtesting and what device? On wireless or wired?
