Boyce01
Internet keeps dropping out for a few minutes
Our virgin WiFi keeps dropping out intermittently for a few minutes at a time. If we reset the router it all tends to work ok for about 24 hours and then the same issues will come back. We have 200mps broadband so should have enough speed to keep us going. Is this an issue anyone else has experienced?
Any tips on how we can try and resolve?
japitts
  • 12.23K
  • 1.7K
  • 2.64K
Re: Internet keeps dropping out for a few minutes
Virgin supply your home with a broadband connection. Your router then converts that into Ethernet (cabled) and wireless (WiFi) connections.
With that in mind, is it your broadband that's dropping or only the wireless - do you have any problems with wired devices?
If you haven't already, I'd recommend spending 5 minutes setting up a free BQM which will monitor your connection 24/7 and make identification of network issues very straightforward.
Hayley_S
  • 1.13K
  • 33
  • 85
Hello @Boyce01,
Welcome to the community page, thank you for posting on here.
I am sorry to see that you are having internet issues.
I can see that you have been asked the correct stuff so we can move forward, please can you answer @japitts response?
Look forward to your response.
Hayley
