  • 6
Internet keeps dropping HELP!!
Afternoon all
I am at my wits end with regards to the internet consistently dropping out at home.  We have been with VM a number of years and up until six months ago we were very happy. We lose the internet daily normally during the day.  It has to be switched off and on again in order for it to normally restart.  We have two key workers working from home and it is causing real issues.  Had two engineers out new router and some tweaks to the configuration on the router.  Nothing seems to have helped.  I have given VM 30 days notice today which I’m not happy about as they have been fab up until six months ago.  Has anyone had the same issues or does anyone have an idea what it could be?  I’d be eternally grateful.  Many thanks.
  • 11.99K
  • 934
  • 1.53K
Re: Internet keeps dropping HELP!!
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Can you post a 'Live Link' to your BQM please.
Then
Can you please
Mike Robinson
