Spardus
  • 6
Message 1 of 25
Internet keeps cutting out every couple of minutes for about 30 seconds.
Any help with this or anyone experiencing the same.
Never had it before, but every 1-2 minutes my internet just won't connect or is extremely slow for about 20-30 seconds, or disconnects from a game or voice chat. Then its back up and this just repeats. Been happening since around 5-6pm UK time.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 25
Re: Internet keeps cutting out every couple of minutes for about 30 seconds.
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 3 of 25
On a wired or wireless connection?
Spardus
  • 6
Message 4 of 25
Have tried resetting and I don't get any joy from that.
The hub is wired and I have tried both wired and wireless to the desktop and neither seem to make a difference
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 5 of 25
Post the network, upstream and downstream logs from the hubs admin pages back here as text
Spardus
  • 6
Message 6 of 25
1195000000040256 qam8
21870000000.740256 qam7
3203000000-0.440256 qam9
4211000000-0.740256 qam10
5219000000-140256 qam11
6227000000-1.540256 qam12
7235000000-1.740256 qam13
8243000000-2.240256 qam14
9251000000-2.540256 qam15
10259000000-2.240256 qam16
11267000000-1.940256 qam17
12275000000-1.740256 qam18
13283000000-1.240256 qam19
14291000000-1.240256 qam20
15299000000-0.440256 qam21
16307000000-0.540256 qam22
17315000000-0.240256 qam23
18323000000-0.540256 qam24
19363000000-3.238256 qam25
20371000000-4.238256 qam26
21379000000-538256 qam27
22387000000-5.538256 qam28
23395000000-5.738256 qam29
24403000000-6.538256 qam30
1Locked40.9410
2Locked40.9310
3Locked40.9160
4Locked40.3210
5Locked40.9180
6Locked40.9170
7Locked40.3280
8Locked40.3200
9Locked40.3230
10Locked40.3330
11Locked40.3260
12Locked40.3210
13Locked40.3340
14Locked40.3290
15Locked40.3300
16Locked40.9270
17Locked40.3320
18Locked40.3250
19Locked38.9140
20Locked38.9290
21Locked38.9200
22Locked38.9300
23Locked38.9260
24Locked38.9250
Spardus
  • 6
Message 7 of 25
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030000049512064 qam1
24620000049512064 qam3
35370000049.8512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
2ATDMA0070
3ATDMA0010
Spardus
  • 6
Message 8 of 25
02/01/2021 23:12:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 23:12:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 23:12:15criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 23:12:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 23:11:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 23:11:15criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 25
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at -6.5dBmV and the highest at +0.7dBmV is too great.
You only have three Upstream Channels, you should have four.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Spardus
  • 6
Message 10 of 25
Okay I will see if I can get someone out, out of curiosity would this just happen randomly there is no specific reason for it? As it has been fine for as long as I can remember and then literally all of a sudden this happened.
is there a cause for it?
