Bumblecake
Internet down - lights on WiFi and arrows flashing green hub 3.0
Internet down - lights on WiFi and arrows flashing green this has now been going on for 8 hours and has been intermittent for a few days now.
  • 82
  • 7
moneill6720
Dialled in
Re: Internet down - lights on WiFi and arrows flashing green hub 3.0
Call up virgin this could be a fault in your area or a issue within your house with the cable/Cable modem they will send out a engineer if nessesary to fix the problem 🙂 other then that have you tried resetting it to factory defaults? and turning it off and leaving it off for 30 mins-1 hour and turning it back on again
Kind regards
max 🙂
Bumblecake
Thanks for the response,
I did reset the router to factory settings before setting up the post, I called through to Virgin and got an automated message advising there was an issue in my area, here's to hoping the issue has been fixed.
Kind Regards,
Ben
  • 5.3K
  • 105
Moderator (Retired) Ty_S
Moderator (Retired)
Hi Bumblecake
Are yous till having any issues with your connection?
I've been unable to locate your account to run some checks so I’ve sent you a private message (purple envelope, top right corner) for some additional information to help me look into this further for you.
Kind regards,
