wilkie1990
Internet connection - intermittent drop outs
Hoping someone here will be able to help.
I have been getting intermittent dropouts on my broadband connection, and this has been happening more often as the days go on.
I have only had virgin for a month, if that, so disappointed to have these sort of issues so soon.
My superhub is in modem mode, and connected to a third party router. The connection is definitely dropping on the hub as I have tested ethernet connections when the broadband goes down.
The logs on the modem at the time of the connection dropping can be seen below.
Any help would be appreciated, having been refused help from the online chat due to using a third party router and told I should contact gadget rescue team! The advisor refused to look at the logs I sent as my hub is not in router mode. I am pretty certain there is an issue with the line based on the logs. While not a networking expert, I do have basic knowledge as I am a software developer.
Thanks for your time
Adam
16/05/2019 21:13:32
critical
Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2019 21:13:32
critical
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2019 21:13:33
critical
16/05/2019 21:13:44
critical
16/05/2019 21:13:44
critical
16/05/2019 21:13:44
critical
16/05/2019 21:14:17
critical
16/05/2019 21:14:17
critical
16/05/2019 21:14:18
critical
16/05/2019 21:18:8
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2019 22:48:20
critical
16/05/2019 22:49:3
critical
16/05/2019 22:49:3
critical
16/05/2019 22:49:17
critical
16/05/2019 22:49:26
critical
16/05/2019 22:49:26
critical
16/05/2019 22:49:27
critical
16/05/2019 22:50:0
critical
16/05/2019 22:50:1
critical
16/05/2019 22:50:1
critical
05/2019 17:36:27
critical
17/05/2019 17:36:27
critical
17/05/2019 17:36:58
critical
17/05/2019 17:36:58
critical
17/05/2019 17:36:59
critical
17/05/2019 17:37:29
critical
17/05/2019 17:37:29
critical
17/05/2019 17:37:30
critical
17/05/2019 17:41:15
critical
17/05/2019 17:53:19
critical
17/05/2019 17:54:3
critical
17/05/2019 17:54:3
critical
17/05/2019 17:54:3
critical
17/05/2019 17:54:4
critical
17/05/2019 17:54:4
critical
17/05/2019 17:54:4
critical
17/05/2019 17:57:53
critical
17/05/2019 18:04:44
critical
17/05/2019 18:09:3
critical
17/05/2019 18:09:59
critical
  • 12.91K
  • 512
  • 1.18K
Re: Internet connection - intermittent drop outs
If you connect a PC under the same MAC as your router to modem mode you can say your testing with a PC to the hub. But it was acceptable in the 90s!
Likely another bad show from online chat had they EVEN checked the logs they would of seem a fault. Can you post the upstream with t# timeouts.
wilkie1990
Thanks for the quick response! Unfortunately as soon as I mentioned I was in modem mode, they became disinterested.
The upstream log is below, everything is set to zero, I have an inkling the hub resets itself at some point after the connection drops as there is a moment where I cannot connect to the ip (192.168.100.1)
Adam
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 12.91K
  • 512
  • 1.18K
Odd your logs show T3 timeouts but the counters show 0....must be x number of timeouts within x seconds to trigger or something.
Can you setup a BQM to see how bad it is.
