  • 9
Intermittent wifi
Having really bad issues with intermittent wifi in Leeds 5. Thought it was our old hub 3 so installed the new hub 4 and still the same.  Ran diagnostics - no issue, rang customer care - and they say extensive issue in the area will be fixed soon. But that has been going on for over a week or more now. Wifi dropped out again halfway through a job application on Friday ! Not a happy bunny now. Can anyone at Virgin explain whats going on please and when I can get a service I can rely on?
  • 12.14K
  • 943
  • 1.56K
Re: Intermittent wifi
Mike Robinson
  • 12.14K
  • 943
  • 1.56K
Can you please
Mike Robinson
  • 9
My BQM
And know can't do anymore cos the signal gone again.
  • 24.99K
  • 1.44K
  • 3.18K
Your BQM (in the little time its ran) shows no drops.
Do wired connections also drop?
  • 789
  • 39
  • 62
Hi there @speedqueen
Thanks for your post. Apologies for the delay in response, we have been very busy and working hard to get to each customer ASAP.
How is the connection at the moment? Has this since been resolved?
Let us know and we'll do our best to advise.
Hollie - Forum Team
