  • 8
Message 1 of 9
Intermittent wifi
All my devices seem to loose WiFi signal and the hub doesn't look any different untill the green WiFi symbol flashes and the devices start to get signal again. Twice I've phoned and both times done all they ask. Both times they told me they'd put a monitor on it, but this time I asked what that means, does it show all the times I've lost Internet? She told me "no the monitoring is done your end, you write down when you have problems" I couldn't believe what she was telling me. So I tried twitter, and was told about some BQM thing. I googled it and signed up to a broadband monitor site and I'm no tech person but I can't see any drops in Internet so I can only assume its the hub.BBut I just don't kno anymore. I can't watch apple TV or Netflix. I can't play online.
While writing this essay it's happened twice
Please send help
Tags (1)
  • 5.87K
  • 1.11K
  • 1.55K
Message 2 of 9
Re: Intermittent wifi
Hello
Can you post the live link to the BQM so we can have a look and will be able to advise better.
Regards Mike
  • 8
Message 3 of 9
  • 24.64K
  • 1.42K
  • 3.14K
Message 4 of 9
So wired connections work?
  • 5.87K
  • 1.11K
  • 1.55K
Message 5 of 9
Hello
Can see no issue with the BQM does the same problems also happen on wired ?
Regards Mike
  • 8
Message 6 of 9
No, my GF was plying playstation wired no problem
  • 8
Message 7 of 9
I've plugged my gaming laptop via ethernet and I'm getting 20fps or less
  • 24.64K
  • 1.42K
  • 3.14K
Message 8 of 9
Then you need to look at optimising the Wi-Fi or putting the hub into modem mode with your own better equipment attached
  • 8
Message 9 of 9
I don't know what that means. But thanks
