  • 26.46K
  • 2.7K
  • 4.9K
Message 21 of 35
Re: Intermittent slow speeds (~0.5Mbps) for 30s, Modem Mode, Normally 300Mbps+
Thats one appalling BQM
Do you have other equipment (Switch/NAS/Powerlines/etc) connected to the Hub on ethernet cables? If so disconnect them all for an hour or two and see if the BQM "cleans up".
As its been a few weeks....  - have you tried a pinhole reset of the Hub as per below (worth doing).
Finally post up all the Hub stats again
__________________________________
Note that a pinhole reset on a Hub3/4 can be a bit problematic - so do it (again) EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections (leave the co-ax connected) and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub
See if that helps
John_GS
  • 10.67K
  • 551
  • 975
Message 22 of 35
Hi XDGFX
Thanks for posting. I am sorry to hear of the broadband issues.
There is an ongoing SNR (signal to noise ratio) issue in your area. F009274456 is the reference and the estimated fix date is the 21st September.
Best,
John_GS
XDGFX
  • 17
Message 23 of 35
Hi John(s)
I only have a single Ethernet cable going from the hub, through a Ubiquiti PoE injector, then into the EdgeRouter. Lots of stuff coming out of the ER.
I've replaced the PoE injector today to see if that helps things. I will try to unplug everything at some point but it might be a while before I can lose complete connection.
No... however I recently got an exciting email from VM saying Gig1 is now available in my area 😉 I've just installed the new Hub 4 today, that should rule out any issues I was having with the Hub 3.
I guess I'll test with the new equipment for the next few days/weeks and see if anything changes. I'm running out of network equipment to replace at this point - so hopefully I find the culprate soon!
My Broadband Ping - VM Quality
Paulina_Z
  • 1.76K
  • 58
  • 112
Message 24 of 35
Hi @XDGFX,
Thank you for coming back to us about this issue, I'm sorry to hear that you're still experiencing this issue.
Please monitor your connection and let us know how you're getting on after the estimates fix time for the SNR outage.
I have checked your account and the estimated fix time is still showing as 21/09/21 at 16:30.
Keep us updated and we'll be more than happy to help if this issue persists.
Thank you,
Paulina_Z
XDGFX
  • 17
Message 25 of 35
So far so good, though I still think it's too early to conclude a fix.
I'm being prompted to return the old VM router. If my issue is fixed the culprit was either the VM router or the PoE injector I replaced. Can my return be marked as potentially faulty to ensure it doesn't make it's way back with the working returns?
Martin_N
  • 6.21K
  • 258
  • 367
Message 26 of 35
Thank you for keeping us posted on this.
Has an agent advised that you return the router?
^Martin
XDGFX
  • 17
Message 27 of 35
Not an agent but when I upgraded to Gig1 it automatically requests a return, I had a reminder text and email a few days ago
Zach_R
  • 1.67K
  • 52
  • 117
Message 28 of 35
Hi @XDGFX,
What model of router do you have that you're being asked to return?
Zach - Forum Team
XDGFX
  • 17
Message 29 of 35
VMDG505 / TG2492LG-VM
Lee_R
  • 3.89K
  • 186
  • 392
Message 30 of 35
Hi @XDGFX thanks for coming back to us.
I'm assuming the faulty hub in question is a hub 3?
Lee_R
