MarkyMark71
  • 16
Message 11 of 24
Re: Intermittent signal dropout
Here are my current upstream power levels...
15370015027.8512064 qam2
23940000027.8512064 qam4
34620000027.5512064 qam3
46030000027.8512064 qam1
3ATDMA0000
4ATDMA0000
  • 35.06K
  • 3.41K
  • 6.67K
Message 12 of 24
@David_Bn   So if all the up channel power levels are way out of range is that ok ?
David_Bn
  • 9.38K
  • 390
  • 715
Message 13 of 24
Hi @MarkyMark71, I'd be happy to have an engineer booked in for you to take a closer look into this for you.
Check out the purple envelope in the top right hand corner for a private message from me.
Kindest regards,
David_Bn
MarkyMark71
  • 16
Message 14 of 24
Just an update....
2nd engineer visit - ran some checks, made a few changes and said he'd lowered downstream power levels and increased upstream to 36. After he left it DC again and I checked upstream levels and all at 31 or 32.
3rd engineer visit - replaced ONU and intinuator and again tweaked power levels.
However, signal is still disconnecting even though upstream are all 41 or 42
There seems to be a mountain of similar posts on here all with one thing in common - Hub 3
I am not relishing the prospect of phoning VM, its like Groundhog Day
MarkyMark71
  • 16
Message 15 of 24
Spoiler
13310000000.236256 qam25
2203000000136256 qam9
32110000000.936256 qam10
42190000000.936256 qam11
52270000000.736256 qam12
62350000000.736256 qam13
72430000000.536256 qam14
82510000000.536256 qam15
92590000000.236256 qam16
102670000000.236256 qam17
11275000000036256 qam18
12283000000-0.236256 qam19
13291000000-0.236256 qam20
14299000000-0.236256 qam21
15307000000-0.236256 qam22
16315000000036256 qam23
17323000000036256 qam24
183390000000.436256 qam26
193470000000.536256 qam27
203550000000.536256 qam28
213630000000.536256 qam29
223710000000.536256 qam30
233790000000.736256 qam31
243870000000.736256 qam32
1Locked36.6180
2Locked36.3640
3Locked36.3280
4Locked36.3260
5Locked36.3460
6Locked36.3440
7Locked36.3320
8Locked36.3240
9Locked36.6260
10Locked36.6210
11Locked36.6200
12Locked36.6370
13Locked36.3460
14Locked36.3600
15Locked36.6560
16Locked36.6720
17Locked36.6620
18Locked36.6220
19Locked36.3300
20Locked36.3390
21Locked36.6260
22Locked36.6130
23Locked36.3180
24Locked36.680
MarkyMark71
  • 16
Message 16 of 24
Spoiler
15370017241.3512064 qam2
23940023341.5512064 qam4
34619999541.3512064 qam3
46030000041.3512064 qam1
1ATDMA0030
2ATDMA0010
3ATDMA0040
4ATDMA0020
MarkyMark71
  • 16
Message 17 of 24
20/06/2022 18:08:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Kath_F
  • 34.67K
  • 1.33K
  • 2.81K
Message 18 of 24
Hi MarkyMark71,
Thanks for coming back to us with an update on this one.
Taking a look at the hub stats from this end, all is looking fine. The levels are within optimal range and there is nothing out of spec with your hub or area.
How are things looking since you last posted?
Pop back and let us know.
Kath_F
MarkyMark71
  • 16
Message 19 of 24
Still the same, constantly disconnecting last night for over an hour and had dropouts today.
This clearly isn't just going to remedy itself and as pretty much everything has been replaced it has to be a network issue doesn't it?
What are VM doing to resolve this?
Natalie_L
  • 6.6K
  • 237
  • 510
Message 20 of 24
Hi MarkyMArk71,
Thank you for getting back to us and letting us know the problems are still happening.
Everything is still running within specification from our side but I see that was the case when your Hub stats were showing very high levels for upstream
With that being the case, are you able to access your Hub and post some up to date stats for us to review?
Nat
