MarkyMark71
  • 16
Message 1 of 24
Intermittent signal dropout
Could someone have a look and advise please, I have been getting intermittent signal dropouts since install a few weeks ago.
Thanks in advance
13310000003.937256 qam25
22030000004.636256 qam9
32110000004.537256 qam10
42190000004.537256 qam11
52270000004.537256 qam12
62350000004.537256 qam13
72430000004.337256 qam14
82510000004.337256 qam15
9259000000437256 qam16
10267000000437256 qam17
112750000003.737256 qam18
122830000003.537256 qam19
132910000003.537256 qam20
142990000003.537256 qam21
153070000003.537256 qam22
163150000003.737256 qam23
173230000003.737256 qam24
18339000000437256 qam26
193470000004.137256 qam27
20355000000437256 qam28
21363000000437256 qam29
223710000004.137256 qam30
233790000004.137256 qam31
243870000004.137256 qam32
1Locked37.650
2Locked36.640
3Locked37.360
4Locked37.350
5Locked37.360
6Locked37.350
7Locked37.350
8Locked37.340
9Locked37.350
10Locked37.350
11Locked37.350
12Locked37.340
13Locked37.390
14Locked37.380
15Locked37.360
16Locked37.640
17Locked37.380
18Locked37.330
19Locked37.360
20Locked37.360
21Locked37.650
22Locked37.650
23Locked37.660
24Locked37.300
MarkyMark71
  • 16
Message 2 of 24
Re: Intermittent signal dropout
@MarkyMark71 wrote:
Thanks in advance
1Locked37.650
2Locked36.640
3Locked37.360
4Locked37.350
5Locked37.360
6Locked37.350
7Locked37.350
8Locked37.340
9Locked37.350
10Locked37.350
11Locked37.350
12Locked37.340
13Locked37.390
14Locked37.380
15Locked37.360
16Locked37.640
17Locked37.380
18Locked37.330
19Locked37.360
20Locked37.360
21Locked37.650
22Locked37.650
23Locked37.660
24Locked37.300
15370000028.3512064 qam2
23940000028.5512064 qam4
34620000028.3512064 qam3
46030000028.5512064 qam1
1ATDMA0010
3ATDMA0000
4ATDMA0000
MarkyMark71
  • 16
Message 3 of 24
13/06/2022 20:52:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2022 20:46:57Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2022 00:34:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 23:12:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 23:08:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 23:01:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 16:53:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2022 08:25:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2022 04:34:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2022 01:30:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2022 05:53:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2022 05:15:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2022 05:15:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2022 09:09:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2022 08:11:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2022 08:11:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2022 08:11:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 35.04K
  • 3.41K
  • 6.66K
Message 4 of 24
All your upstream power levels are too low. Recommended minimum is +35 dBmV yours are in the 20's.
It will require a tech visit to investigate, Try calling it in as a fault but if they dont want to do anything, wait till a VM person responds on here in a day or two and can sort it for you
MarkyMark71
  • 16
Message 5 of 24
Thank you John, I really appreciate your help
MarkyMark71
  • 16
Message 6 of 24
Still looking for assistance if VM mod is available please. Spoke to tech who first said there was no issue but then agreed there was. They said they were fixing it remotely and to monitor for 24 hours but 48 hours on it us as bad as ever. Please help!
David_Bn
  • 9.36K
  • 388
  • 712
Message 7 of 24
Good Afternoon @MarkyMark71, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the intermittent drop outs you're experiencing.
How are things looking today?
I've looked into the stats of the hub, and everything appears to be within spec.
We do however notice that a Wi-Fi connection may be problematic at the moment, with some interference being detected.
Can you please advise me if any devices close to the hub can be placed on a wired connection?
Do you notice any connection issues when using Ethernet cables?
Kindest regards.
David_Bn
MarkyMark71
  • 16
Message 8 of 24
Hi David,
The VM stream box is connected via ethernet and when the signal drops out so does the stream box.
MarkyMark71
  • 16
Message 9 of 24
Also, it went off last night numerous times and has done so again this afternoon.
  • 35.04K
  • 3.41K
  • 6.66K
Message 10 of 24
Post the Upstream power levels again. David is saying they are back in range.
