  • 26
Message 1 of 10
Intermittent problems for 4+ days
I have been experiencing intermittent broadband problems for 4 days. Download speeds are generally fine but upload speeds have been very slow resulting in web pages or the pages failing to load similar problems with Netflix.
Status Page currently says no problems. Have tried to contact VM the message on 150 is that all the call centres are closed. BQM graph below, I’m guessing that all that red is not a good sign. Any help would be much appreciated.
  • 3.65K
  • 283
  • 513
Superfast
Message 2 of 10
Re: Intermittent problems for 4+ days
Call centres are NOT closed.
Text VM on 07533051809.
  • 26
Message 3 of 10
BQM Graph:
My BQM
  • 11.9K
  • 929
  • 1.53K
Message 4 of 10
Can you please
Mike Robinson
  • 26
Message 5 of 10
Well I've texted that number no reply and the message I have been getting for the last 4 days when I call VM is our call centres are closed.
  • 3.65K
  • 283
  • 513
Superfast
Message 6 of 10
What numbers are you using?
0345 454 1111
Plenty of people posting on here getting through to the call centres...
  • 26
Message 7 of 10
Channel               Frequency (Hz) Power (dBmV)  SNR (dB)              Modulation        Channel ID
1              203000000           3.7          40           256 qam              9
2              139000000           4.3          40           256 qam              1
3              147000000           4.5          40           256 qam              2
4              155000000           4.6          40           256 qam              3
5              163000000           4.3          40           256 qam              4
6              171000000           4.1          40           256 qam              5
7              179000000           4              40           256 qam              6
8              187000000           4              40           256 qam              7
9              195000000           3.9          40           256 qam              8
10           211000000           3.5          40           256 qam              10
11           219000000           3.5          40           256 qam              11
12           227000000           3.4          40           256 qam              12
13           235000000           3.2          40           256 qam              13
14           243000000           3.2          40           256 qam              14
15           251000000           3              40           256 qam              15
16           259000000           3              40           256 qam              16
17           267000000           3.2          40           256 qam              17
18           275000000           3              40           256 qam              18
19           283000000           3              40           256 qam              19
20           291000000           2.7          40           256 qam              20
21           299000000           2.9          40           256 qam              21
22           307000000           2.7          40           256 qam              22
23           315000000           2.5          40           256 qam              23
24           323000000           2.5          40           256 qam              24
Channel               Locked Status    RxMER (dB)        Pre RS Errors      Post RS Errors
1              Locked  40.3        229         0
2              Locked  40.3        399         0
3              Locked  40.3        384         0
4              Locked  40.3        131         0
5              Locked  40.3        260         0
6              Locked  40.3        471         0
7              Locked  40.3        796         0
8              Locked  40.3        405         0
9              Locked  40.9        22           0
10           Locked  40.3        94           0
11           Locked  40.3        143         0
12           Locked  40.9        52           0
13           Locked  40.3        44           0
14           Locked  40.9        86           0
15           Locked  40.3        13           0
16           Locked  40.3        6              0
17           Locked  40.3        7              0
18           Locked  40.3        9              0
19           Locked  40.3        6              0
20           Locked  40.3        41           0
21           Locked  40.3        5              0
22           Locked  40.9        8              0
23           Locked  40.3        84           0
24           Locked  40.3        254         0
Channel               Frequency (Hz) Power (dBmV)  Symbol Rate (ksps)          Modulation        Channel ID
1              46200000             43.5        5120       32 qam 3
2              39400000             44           5120       32 qam 4
3              53700000             44           5120       32 qam 2
4              60300000             44           5120       32 qam 1
Channel               Channel Type     T1 Timeouts       T2 Timeouts       T3 Timeouts       T4 Timeouts
1              ATDMA 0              0              4              0
2              ATDMA 0              0              85           0
3              ATDMA 0              0              15           0
4              ATDMA 0              0              0              0
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;fg87dsfd;kfoA,.iyewrkldJ
SFID       6938
Max Traffic Rate               117000047
Max Traffic Burst              42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID       6937
Max Traffic Rate               10500047
Max Traffic Burst              16320
Min Traffic Rate 0
Max Concatenated Burst              16320
Scheduling Type               BestEffort
Time      Priority Description
08/11/2020 14:16:36       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:16:35       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:13:56       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:13:56       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:12:36       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:12:36       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:07:16       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:07:16       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:04:37       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:04:36       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:20:41       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:20:41       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:14:3         critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:14:2         critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:12:42       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:12:41       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:11:22       critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:11:22       critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:10:2         critical   No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:10:2         critical   Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 26
Message 8 of 10
150 is the number I have been using.
  • 3.65K
  • 283
  • 513
Superfast
Message 9 of 10
Upstream channels out of spec (Should be 64 qam), causing T3 timeouts:
1 ATDMA 0 0 4 0
2 ATDMA 0 0 85 0
3 ATDMA 0 0 15 0
4 ATDMA 0 0 0 0
  • 7.69K
  • 461
  • 486
Message 10 of 10
Hi MrBiffo,
Very sorry for the delay in getting back in touch, we have been busier than usual.
I'd also like to apologise for the issues you've been having. I have had a look into the back end of things and can see since posting you've been able to speak to the team.
I trust everything is all sorted now but if you need anything else do let us know.
Emma_C - Forum Team
