on 09-05-2023 21:19
Hi folks,
Have been experiencing intermittent loss of internet to devices connected to my Hub 4 for the last few months.
Some days it works absolutely fine (and I get good speeds when it does), other days I frequently lose internet connection for a couple of minutes at a time. May be confirmation bias, but it feels like it's happening more and more often.
This happens with WiFi connections, and also when using a powerline adapter to route the signal through the house's electrical wiring. Curiously, it doesn't seem to be a problem when a device is plugged directly into the hub via ethernet cable.
I'm no IT expert, but I know a little and;
This happens with every device on my network and I'm running out of ideas.
The image below is taken using the WTFast VPN program and shows ping dropping to 0 for approx. 3 minutes during a gaming session, as an example of what I'm experiencing.
Any help or advice on resolving this would be appreciated - it's getting quite frustrating at this point.
Jonathan
on 10-05-2023 08:31
Set up a BQM.
Odd that wired is okay though.
on 10-05-2023 09:10
Thanks. I'd never heard of a BQM before but seems useful. I'll see about getting that set up today.
on 14-05-2023 20:36
So this has been fine all week since I posted - issue cleared up entirely. Today it returned with a vengeance.
Ping graph from WTFast VPN program for a approx. 25 minute session today - notice the multiple times throughout that the ping drops to zero;
Compared with a "normal" graph from when the connection was working perfectly yesterday - consistently in the 75-85ms range with no dropouts over a 90 minute period;
And here's the Broadband Quality Monitor graph showing no issues (the single redline is from my resetting the Hub4);
on 16-05-2023 20:53
Many apologies for the issues faced jonathangillis,
Welcome back to the community.
Are you still receiving the same intermittency since posting?
Regards,
