Intermittent loss of network, still connected.
Kasual
We have recently moved home (roughly 3 months), had VM moved to our new address and was perfectly fine for the first 2 months. For the last few weeks now the internet will drop altogether, however, stay connected to the network.
Usually, I'll be playing a game, Warzone/FIFA/Call Of Duty/Minecraft, etc and the same issue, the game halts, my character jumps about and then most times followed by a disconnection from the game. However, my PC will remain connected to the network with internet access.
Now, if I try to browse a webpage on my computer, it will just spin until the network wakes up and the same on my mobile phone.
My PC is wired via Ethernet.
My mobile phone is connected wirelessly.
The only logical explanation I can fathom is that there is over-utilization.
We cannot continue to pay for a service that isn't provided. I will be moving home again soon to 'fly-solo' and was going to go with VM. However, it's putting me off at present.
13 REPLIES 13
Kasual
3.0 Downstream channels
21470000002.40000234.925610QAM2562
11390000003.00000034.925610QAM2561
31550000001.90000234.483570QAM2563
41630000001.59999834.345688QAM2564
51710000001.09999834.483570QAM2565
61790000000.79999934.483570QAM2566
71870000000.79999934.483570QAM2567
81950000000.59999834.483570QAM2568
92030000000.40000234.483570QAM2569
102110000000.29999934.925610QAM25610
112190000000.29999933.834164QAM25611
122270000000.00000034.483570QAM25612
13235000000-0.20000134.925610QAM25613
14243000000-0.29999934.925610QAM25614
152510000000.00000034.345688QAM25615
16259000000-0.09999835.083549QAM25616
172670000000.09999835.779911QAM25617
182750000000.59999835.595078QAM25618
192830000001.00000035.595078QAM25619
202910000001.00000035.779911QAM25620
212990000000.09999835.779911QAM25621
22307000000-0.40000235.779911QAM25622
23315000000-0.90000235.595078QAM25623
24323000000-0.90000235.779911QAM25624
25331000000-0.90000235.083549QAM25625
26339000000-1.00000035.779911QAM25626
27347000000-1.00000035.083549QAM25627
28355000000-1.29999935.083549QAM25628
29363000000-1.20000135.595078QAM25629
30371000000-1.50000034.925610QAM25630
31379000000-1.50000034.925610QAM25631
2Locked34.9256101280
1Locked34.9256101520
3Locked34.4835702700
4Locked34.3456882420
5Locked34.4835702120
6Locked34.4835703020
7Locked34.4835704880
8Locked34.4835702380
9Locked34.4835702400
10Locked34.925610940
11Locked33.83416435460
12Locked34.4835701980
13Locked34.9256101180
14Locked34.925610770
15Locked34.3456884280
16Locked35.083549150
17Locked35.77991160
18Locked35.595078110
19Locked35.59507830
20Locked35.77991100
21Locked35.77991160
22Locked35.77991100
23Locked35.59507880
24Locked35.779911140
25Locked35.083549150
26Locked35.77991160
27Locked35.083549130
28Locked35.083549200
29Locked35.595078110
30Locked34.925610390
31Locked34.925610500
3.0 Upstream channels
14310000040.7705995120 KSym/sec16QAM2
23010000040.7705995120 KSym/sec16QAM4
33660000040.7705995120 KSym/sec16QAM3
44960000041.0205995120 KSym/sec64QAM1
52360000039.7705995120 KSym/sec64QAM9
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
5US_TYPE_STDMA0000
3.1 Upstream channels
1010.836.52KQAM8
10OFDMA22053.400
The 'Network Log' is empty.
Channel 11 downstream looks like it’s affected by noise ingress, possibly cause by DAB radio, 3 of the 5 upstream are 16 QAM when they should be 64 QAM. Check that all connections are tight and see if there are any area faults.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
Thanks, Tudor.
No DAB Radio's here 😄
I already have checked the connections. However, I will check again tomorrow as it's getting late here now.
There are no logged faults in the web status. I can check with VM directly tomorrow also.
Thanks again.
So, all connections are tight and there are no issues in the area.
Also, the network seems completely fine at the moment. Yesterday a ping test showed "request timed out" multiple times over a long duration. However, no time-outs at present.
The issue seems to be more common around 6:00 PM onwards.
Issue with the upstream channels seems to have shifted more positively:
However, the channels are still below 64QAM.
14310000041.0205995120 KSym/sec32QAM2
33660000041.0205995120 KSym/sec16QAM3
44960000041.2705995120 KSym/sec64QAM1
9
Here's an active BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5ad0c5c2eb9fef7ad0628b9d8d149158f2d9a020
Hey Kasual,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your connection, I have looked into this on our system and can see that there are a few issues with your connection that would need a technician visit to resolve, the SNR levels of your connection are too low and upstream power levels too high.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment. Please look out for the private message and we can get started.
Kind Regards,
Steven_L
Many thanks, Steven_L.
Apologies for the delay, I have responded back to your private message.
Great!
Steven will assist further 😊
All the best!
Ayisha_B
