  • 13
Message 1 of 24
Intermittent loss in hard wired connection
I am trying to work from home and experiencing a regular intermittent loss in connection. I am hard wired to a laptop but signal is dropping on average 5-6 times per hour. I have had an engineer who came and checked the cables from the main cable box in the street to my house and he thought it was just a weak signal due to a line being shared. I have also tried factory resetting the hub and neither has resolved the connection issues. Does anyone have any other suggestions as this is impossible to get any work done.
  • 24.39K
  • 1.4K
  • 3.1K
Message 2 of 24
Re: Intermittent loss in hard wired connection
Post the Network, Upstream and Downstream logs from the hubs admin pages
  • 13
Message 3 of 24
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
5.4
40
256 qam
1
2
147000000
5.3
40
256 qam
2
3
155000000
5.1
40
256 qam
3
4
163000000
4.8
40
256 qam
4
5
171000000
4.5
40
256 qam
5
6
179000000
4.3
40
256 qam
6
7
187000000
3.9
40
256 qam
7
8
195000000
3.4
40
256 qam
8
9
203000000
3
40
256 qam
9
10
211000000
2.7
40
256 qam
10
11
219000000
2.7
40
256 qam
11
12
227000000
2.7
40
256 qam
12
13
235000000
2.2
40
256 qam
13
14
243000000
1.7
40
256 qam
14
15
251000000
1.5
40
256 qam
15
16
259000000
1.7
40
256 qam
16
17
267000000
1.5
40
256 qam
17
18
275000000
1.5
40
256 qam
18
19
283000000
1.5
40
256 qam
19
20
291000000
1.2
40
256 qam
20
21
299000000
1.5
40
256 qam
21
22
307000000
1.2
40
256 qam
22
23
315000000
1
40
256 qam
23
24
323000000
0.7
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
22
0
2
Locked
40.3
39
0
3
Locked
40.3
35
7
4
Locked
40.3
28
205
5
Locked
40.3
16
0
6
Locked
40.3
6
0
7
Locked
40.9
8
0
8
Locked
40.9
6
0
9
Locked
40.9
7
0
10
Locked
40.3
7
0
11
Locked
40.9
8
0
12
Locked
40.3
5
0
13
Locked
40.3
8
0
14
Locked
40.3
4
0
15
Locked
40.9
5
0
16
Locked
40.3
8
0
17
Locked
40.3
10
0
18
Locked
40.3
12
0
19
Locked
40.3
12
0
20
Locked
40.3
7
0
21
Locked
40.9
5
0
22
Locked
40.3
8
0
23
Locked
40.3
27
0
24
Locked
40.3
11
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
4.25
5120
64 qam
11
2
39400000
4.3
5120
64 qam
10
3
46200000
4.35
5120
64 qam
9
4
25800000
4.2
5120
64 qam
12
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
  • 24.39K
  • 1.4K
  • 3.1K
Message 4 of 24
When was the hub last rebooted?
  • 17.25K
  • 1.82K
  • 2.99K
Message 5 of 24
Also post the Network logs.
Also, in the meantime, if you haven’t already, set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” (as per instructions on the TB website) when you have the first 24h period.
  • 13
Message 6 of 24
I did the factory reset that was suggested on the Virgin media page this morning before posting on the forum. Still getting breaks in connection.
  • 17.25K
  • 1.82K
  • 2.99K
Message 7 of 24
FYI
Note that a pinhole reset on a Hub3 can be a bit problematic - so do it (again) EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT restart the Hub after that. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub (it is a six digit numeric one).
See if that sorts it.
  • 13
Message 8 of 24
Virgin engineer was here on the 21st
network log
27/10/2020 13:40:35noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/10/2020 10:53:45noticeSW download Successful - Via Config file27/10/2020 10:51:35noticeSW Download INIT - Via Config file27/10/2020 00:07:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/10/2020 08:03:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 22:01:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:41:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:34:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/10/2020 13:25:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 13
Message 9 of 24
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/02352fa90ee43cf914733bb6cf38541efcb55800-28-10-2020">My Broadband Ping</a>
  • 3.44K
  • 270
  • 465
Superfast
Message 10 of 24
Sounds an odd request however could you connect wirelessly to see if the issue persists?
You could have a faulty HUB (I've seen similar threads where the ethernet connections would drop intermittently, however wireless was ok).
The BQM doesn't look too bad (Some minor packet loss).
